 Post subject: Can I show the Desktop Modules ONLY with a bump?
PostPosted: Wed Oct 14, 2009 6:09 pm
Is it possible to make the Desktop Modules on the Desktop appear with a bump by itself (as a group or individually) while the Browser or folder is open like the Docks? I've tried numerous settings, but at the moment it will only appear when I bump the Top Shelf.
PostPosted: Wed Oct 14, 2009 6:35 pm
Create a new hotspot in NextSTART, set the activation method (Launch With) to a bump on one of the screen edges/corners, and set the Hotspot Action to 'Internal Command' and 'Show/Hide Desktop Modules'.
PostPosted: Thu Oct 15, 2009 3:58 am
Sorry, I don't know what a hotspot is or where or how to make one. I don't see that anywhere. Please instruct me on how to do this. Thanks. :)
PostPosted: Thu Oct 15, 2009 6:18 pm
1 - Open NextSTART Preferences
2 - Go to the Hotspots Editor tab.
3 - Click on the Add button.
4 - Change 'Left Click on Hotspot button' on the Launch with section to Bump screen <edge/corner>
5 - Change the Hotspot Action to 'Run Internal Command'
6 - Select 'Show/Hide Desktop Modules' from the Command Name section
7 - Press Ok.
8 - Bump the selected screen edge/corner to test.
PostPosted: Fri Oct 16, 2009 5:59 am
Thanks, it works except for one little nagging problem. Once you click anywhere on the Browser or folder (while it's open fully so the Top Shelf Menu doesn't show which is the way I set it ), the Desktop Module won't appear with a bump unless I bump either the Top Shelf or a Dock.
If I don't click on anything it works fine. The Browser or folder has to be reopened for it to work without bumping something else. Minimizing won't clear it.
PostPosted: Thu Oct 22, 2009 9:24 pm
Can you show me a screenshot of your desktop with NextSTART Preferences open on the Hotspots Manager tab *and* the hotspot you added selected?
Thanks,
PostPosted: Sat Oct 24, 2009 3:13 am
Not sure if I'm posting the info you asked for, but here it goes.
BTW, can you also tell me how to remove a blank space that I somehow caused to be in my Context Menu? I've pointed it out one of the screenshots.
PostPosted: Sat Nov 07, 2009 7:09 pm
Any luck with either requests? How do I remove the empty space in the menu that I show above?
PostPosted: Mon Nov 09, 2009 3:59 pm
Not sure about the bump problem, sorry.
As for the blank space in the menu, that is a menu item separator, you can't remove it. On skins that support separators, it would actually look like a separator, but that theme was made before I added menu item separator support to NextSTART menus. Hope this makes sense. :wink:
 Post subject: thanks
PostPosted: Mon Nov 09, 2009 6:22 pm
i pm'ed you about creating a desktop toolbar on nextstart for my friend. thanks to this i was able to create a hotspot for his desktop items. thanks.
as for removing the separator yes you can. my startmenu i deleted all the separators and renamed or added what i needed / wanted then i added the separators where i wanted them.
uptime
new office document
windows update
separator
programs
separator
info
search
settings
run
separator
computer
desktop
disk
network
connect to
separator
exit
windy any chance of posting your desktop here?
http://forums.winstep.net/phpBB2/viewtopic.php?t=2929&highlight=post
PostPosted: Mon Nov 09, 2009 6:35 pm
Not those in context menus. :wink:
 Post subject: my bad
PostPosted: Mon Nov 09, 2009 6:54 pm
my bad, must have missed seeing that it was about context menus.
PostPosted: Tue Jan 19, 2010 9:12 am
The above was from earlier in this thread. I was tinkering around and found the solution to my problem.
I right-clicked NeXus >Preferences >Modules tab >selected a module >Advanced >under the heading Desktop Module: used the pull-down arrow and selected Always above other Windows, and >selected a screen edge.
Now I can bump the screen edge to hide the Modules without first un-hiding a Dock. The only thing that does not function now is that unlike the Docks and Workshelf, the Modules can't be hidden by clicking on an empty area on a web page or open folder.
Am I missing something?
Users browsing this forum: DuckDuckGo [Bot] and 100 guests
