 Post subject: System tray problem
PostPosted: Mon Nov 02, 2009 9:28 pm
In the nextstart preferences i checked the box to "detatch systray from start bar". I noticed that the system tray icons were now under the start bar.
I decided that i wanted to restore the system tray back to it's normal state (back on top of the start bar), so i went back into preferences and unchecked "detatch systray from start bar". Now the icons are back on top of the start bar and seem to be in the correct position, however when i click on the expand button (the little arrow to the left of the system tray icons), the icons expand to the right...overlapping the clock. Has anybody else experienced this problem?
I am running windows xp 32-bit sp3.
PostPosted: Mon Nov 02, 2009 9:46 pm
Never mind. I restarted winstep xtreme and it returned to normal.
PostPosted: Tue Nov 03, 2009 11:00 am
Glad to know. :D
Users browsing this forum: Amazon [Bot], Google [Bot] and 113 guests
