 Post subject: Popup problem with Nexus in Win7
PostPosted: Wed Sep 30, 2009 1:26 am
I have had Win7 rc running since it came out and just put Nexus on today. I have a problem when I right click on the desktop the popup comes on and goes back off. If I do this several times the popup will stay on. Also when I right click the trash can to empty it, that does the same thing on and off.
Any ideas or something to uncheck to fix this.
I am running Winstep Xtreme 9.5
Thanks...Stephen
PostPosted: Wed Sep 30, 2009 9:53 am
I rebooted and the problem went away.
I was scratching my head there for a moment.
PostPosted: Wed Sep 30, 2009 7:17 pm
Ah, the famous ER and TOTO troubleshooting methods, how they work for 90% of all PC problems!
ER = Exit and Restart, TOTO = Turn it Off then Turn it On again. :wink:
Users browsing this forum: GPT [Bot] and 44 guests
