 Post subject: Workshelf Behavior Issue
PostPosted: Sat Aug 15, 2009 6:21 pm
Using 9.7, I have the following Workshelf Behaviors checked:
- Acitvate shelf by bumping screen edge
- Automatically activate shelf on mouseover
- Select a different tab just by mousing over it
All behaviors work as expected. However, when I go into the advanced behavior properties and select "Hide tabs when the shelf is collapsed", the behavior "Select a different tab just by mousing over it" no longer works. I must click on the tab I want to use.
Is this normal behavior?
PostPosted: Tue Aug 18, 2009 1:24 pm
Sounds like a bug, I'll have to check it out. You obviously mean the mouseover no longer works when the Shelf is uncollapsed, right?
PostPosted: Tue Aug 18, 2009 9:44 pm
That's correct Jorge
PostPosted: Sun Mar 07, 2010 9:36 pm
Jorge, I'm using the newest beta and still have the mouseover issue. Any ideas?
Users browsing this forum: Amazon [Bot], Bing [Bot] and 31 guests
