 Post subject: Noob questions
PostPosted: Mon Jun 22, 2009 6:01 pm
I need icons for Nexus, how do I input them?
PostPosted: Mon Jun 22, 2009 6:34 pm
Not sure I understood your question, sorry.
Do you want to know where you can find more icons OR you want to know how you can customize the icons of applications you've already placed in the dock?
PostPosted: Mon Jun 22, 2009 7:09 pm
Just how to use in Nexus...maybe later I can learn to find some on net and use....but for now I want to learn how to put an icon od a Nexus shortcut. I'm gonna use Nexus to make a shortcut to my GMail, but I don't see an icon up on the Nexus bar.
PostPosted: Mon Jun 22, 2009 7:30 pm
Ok firstly save this image to your desktop or somewere similar
Now drag the icon into your dock.
Now right click the Gmail icon in your dock and select "Dock Entry Properties" or something similar.
Change the item type to a URL and then add the URL of your Gmail account in the box provided.
Hope that helps
PostPosted: Mon Jun 22, 2009 8:48 pm
Thank you very much!
When I first put in the URL and hit 'enter' it lost the icon, I put in the path to where I have it....I got a feeling that it may not be safe there....is there a safe document folder that the icon could be stored?
PostPosted: Mon Jun 22, 2009 9:23 pm
Open 'My Documents'. You should see a shortcut to the Winstep user data folder there. Double click it. You should now see a folder saying 'Icons'. Double click it too. Now put your icon inside the 'Samples' folder.
PostPosted: Tue Jun 23, 2009 12:08 am
Thank you :)
PostPosted: Tue Jun 23, 2009 12:50 am
Don't mention it. :wink:
Users browsing this forum: Google [Bot], GPT [Bot] and 60 guests
