 Post subject: Winstep Xtreme 9.5 released!
PostPosted: Mon May 25, 2009 2:21 pm
An integrated workspace environment, Winstep Xtreme is a powerful suite of applications that merge incredible usability and performance with breathtaking eye candy.
Winstep Xtreme's 8.11 release last December brought the Windows 7 "Superbar" to the Windows XP and Vista world. With Windows 7 Release Candidate (RC) now available, the new 9.5 release also ensures that Winstep Xtreme is fully compatible with both the 32 bit and 64 bit versions of what will soon become Microsoft's new flagship Operating System.
You can download the new Winstep Xtreme 9.5 version from HERE.
Highlights in this release:
New and improved systray (system notification area) replacement. No more occasional visual 'glitches'.
Glass Blur feature that automatically blurs whatever is behind semi-transparent docks, shelf, menus, startbar and desktop modules (Vista and Windows 7 only).
Ability to colorize existing themes, thus permiting thousands of different color variations on the same theme.
Full compatibility with all 64 bit versions of Windows.
Full Windows 7 compatibility.
Ability to rescale desktop modules (very useful when running on systems with low screen resolutions).
Winstep Xtreme remains fully responsive even when launching extremelly heavy applications.
Docks can now be disabled and thus temporarily prevented from showing on-screen while at the same time preserving their contents. Very useful in multi-dock environments.
Docks can now be offset from the screen edge they are docked to by up to 128 pixels.
Small 'close' buttons on task and task group menus now allow the user to quickly close a windows without having to right click on the menu task entry first.
The Net Meter module now properly recognizes Wireless connections as such.
Fixed some miscellaneous issues.
... and much, much more!
There are many other additions and fixes in the Winstep Xtreme 9.5 release. You can see a complete list of changes to the WorkShelf and NeXuS components HERE and to the NextSTART component HERE.
PostPosted: Tue May 26, 2009 3:58 pm
Congrats Jorge! Very nice update for us early adopters of Win7!
kwickone I.T.H.
PostPosted: Wed May 27, 2009 3:16 am
Thanks! :D
PostPosted: Wed Jul 01, 2009 9:07 pm
thankyou very much
Users browsing this forum: Amazon [Bot], Apple [Bot], Majestic-12 [Bot] and 43 guests
