 Post subject: newbie questions
PostPosted: Thu Apr 01, 2004 2:50 am
I'm using the demo of nextstart (regular users, not corporate) and I really like it :D, but I have a couple of questions. First of all, how do I change the wallpaper when using a theme to one in my pictures folder? Some of them are quite nice, but I'd still like to use my own every once in a while.
Secondly, how do I switch to the explorer shell and back to nextstart when I want to? This is important because I'm not the only one who uses the computer.
Thanks in advance.
PostPosted: Thu Apr 01, 2004 2:53 am
In NS Preferences, if you go to the Themes (icon on the top with the tuxedos), click the button that says Theme Options. In the pop-up window, click the checkbox for Lock Wallpaper. Then you can change your wallpaper to anything you want using Display Properties or whatever and NS will leave it alone.
 Post subject: Re: newbie questions
PostPosted: Thu Apr 01, 2004 4:14 am
To go back to Explorer all you have to do is exit NextSTART. Yes, as simple as that. :)
If each of the persons using the computer have their own login, you can also enable NextSTART's multi-user mode. In this mode each user can have their own theme and settings - and even choose to run NextSTART automatically when they login or not.
PostPosted: Fri Apr 02, 2004 4:20 am
Cool, thanks. :D
Exit nextstart, duh. I was afraid that would leave me without a shell. :oops: Should've tried it.
PostPosted: Fri Apr 02, 2004 5:57 am
Hehe. :D
Users browsing this forum: Amazon [Bot], Google [Bot] and 111 guests
