 Post subject: Weather Widget
PostPosted: Tue May 05, 2009 3:23 pm
Jorge, I can't figure out why my weather widget won't import the data for Cincinnati, Ohio. It does for the sun/cloud image and temperature, but for the forecast I just get N/A.
Any thoughts?
Dr.J.
PostPosted: Tue May 05, 2009 4:04 pm
Open the Weather Module Preferences dialog. What are the METAR and Weather.com codes?
PostPosted: Tue May 05, 2009 6:54 pm
Metar: KLUK
Weather.com is empty...and I don't know where to find the info, Jorge...and thanx for the reply, my friend!
Dr.J.
PostPosted: Tue May 05, 2009 7:13 pm
Type USOH0188 into the Weather.com field. Not sure why you don't have that code, though, since it is in the Weather locations database.
PostPosted: Tue May 05, 2009 9:28 pm
Not sure either...but thanks!
Dr.J.
Users browsing this forum: Amazon [Bot] and 68 guests
