 Post subject: Menus
PostPosted: Sat Mar 14, 2009 3:19 pm
How do you add vertical separation between flyout menus and the menu it came from they appear to touch, I have found the menu OVERLAP feature but I do NOT want over lap. I am talking about the "Start" menu and there after. :?:
PostPosted: Sat Mar 14, 2009 3:25 pm
Using the overlap setting with a negative value should work.
PostPosted: Sat Mar 14, 2009 10:05 pm
you can only enter a numerical value. I just tried.
PostPosted: Sun Mar 15, 2009 3:37 pm
Thanks for pointing it out. Try the following: open notepad and type in the negative number. Now copy it (CTRL+C) and paste it (CTRL+V) into the overlap field - that will work, just tried it. :D
 Post subject: THANKS
PostPosted: Wed Mar 18, 2009 5:15 am
I did the cut and paste thing with the neg value, it worked perfectly.
I did notice that with the "-" sign you now only have up to 9 pixels as you offset/overlap as the "-" is taking up one of the two allowed characters for that field. Will this be corrected in a future version?
PostPosted: Wed Mar 18, 2009 5:22 am
Yes. :-)
Users browsing this forum: Amazon [Bot], Google [Bot] and 100 guests
