Board index : Winstep Forums : General Discussion  [ 34 posts ] Go to page Previous  1, 2, 3
PostPosted: Tue Dec 09, 2008 10:53 am
I switch the taskbar to style 7 and i see the icons of my running programs. If i mouseover a grouped task a popup-list opens with the icons and labels of my running tasks. As i understood, i should see on this level all previews of the grouped tasks?
If you are not seeing the grouped window thumbnails and instead get the grouped tasks menu on mouseover, that's because you have the 'Open Group on Mouseover' option selected (NextSTART Preferences -> Tasklist and Systray Preferences). Just disable that option. :D
 Post subject: Windows 7 feature
PostPosted: Tue Dec 09, 2008 11:10 am
Working! Great!
but how should a user know this?
I think, it make sense, that if i select the Windows 7 Style, that all parameters are set so that i'm getting the Windows 7 Style. I think, that was my biggest problem.
Thanks for the fast response Jorge!
If you don't correct an error you have done a second one
PostPosted: Tue Dec 09, 2008 11:25 am
That option is disabled by default, so new users won't run into the problem you did. And if they then enable that option, they will know immediately what caused the change.
PostPosted: Tue Dec 09, 2008 7:52 pm
Official 8.11 version has just been released, so the beta link is now inactive. :D
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 34 posts ] Go to page Previous  1, 2, 3
Users browsing this forum: Google [Bot] and 49 guests
