 Post subject: NEXUS Disappeared
PostPosted: Sat Mar 15, 2008 1:22 pm
NEXUS stopped loading and I can't get it to run. Any ideas on how to correct?
PostPosted: Sat Mar 15, 2008 5:35 pm
Do you still see the shelf?
PostPosted: Sat Mar 15, 2008 9:20 pm
yes, the shelf is fine. This only started after i updated to the latest Stardock version of Deskscapes.
PostPosted: Sat Mar 15, 2008 9:55 pm
Hmmm, I doubt very much this has anything to do with it.
Hopefuly you haven't deleted the dock by accident. Couple of things to do:
1 - Make a backup of your WorkShelf settings (right click on the left mini-tab -> Backup) and send the resulting file to the Winstep support address.
2 - Right click on the shelf's left mini-tab and select 'Create New Dock'. Do you see the new dock? You can then delete the empty new dock by right clicking on the NeXuS icon-> Dock Management -> Delete Dock).
PostPosted: Sat Mar 15, 2008 10:28 pm
When you asked if the shelf was there. Did you mean Workshelf or the Nexus shelf. Work Shelf appears but not the NEXUS shelf.
PostPosted: Sat Mar 15, 2008 10:36 pm
Ok, let's see: the shelf is the tabbed dock. NeXuS are the docks without tabs (the ones where the control icon says 'NeXuS'). WorkShelf is the application responsible for both the shelf and the NeXuS docks. :D
Users browsing this forum: Amazon [Bot] and 62 guests
