 Post subject: Things to come... :-)
PostPosted: Wed Mar 12, 2008 5:37 pm
Check out the new icon reflection effect:
and
Don't mind the in-dock modules not having a reflection yet, still working on it. :D You can also set the reflection size, by the way (i.e. in this case it is half an icon, but it can go up to the full icon being reflected). This will be a per dock/shelf special effect setting.
PostPosted: Thu Mar 13, 2008 10:03 am
:shock:
That looks awesome! Bring it on :)
http://www.scarebear.org/
PostPosted: Fri Mar 14, 2008 8:43 pm
Here is another shot, featuring a Mac OSX Leopard theme:
Compare it to the real thing here:
Not bad, heh?
PostPosted: Fri Mar 14, 2008 8:57 pm
Not bad, heh?
Pffttt... Better! :D
PostPosted: Sat Mar 29, 2008 7:10 am
Out of curiosity, how will reflections work (if at all) when the dock is on the bottom, left or right? Screenshots? ;)
If I'm going to start a new theme I'd like to know what to consider for the dock.
PostPosted: Sat Mar 29, 2008 11:33 am
Yes. but remember that icon reflections are always vertical (i.e. below the icon) regardless of the dock orientation. Anyway, I don't think you need to take reflections into consideration when making your theme - for starters it is all automatic and will work with any theme, second it is a per user setting as is how much the icon is reflected.
Users browsing this forum: Apple [Bot] and 60 guests
