 Post subject: Install error
PostPosted: Wed Mar 12, 2008 2:35 am
When I try to install Winstep, I get an "Error 5: Access is denied", which is being shown because "Setup was unable to create the directory ...\Documents\Winstep"
Anyone have a solution?
PostPosted: Wed Mar 12, 2008 11:58 am
1 - What Windows version are you running?
2 - Are you running with an Admin account?
3 - If Vista, are you running with the UAC enabled or disabled?
4 - Does setup display the full '...\Documents\Winstep' path or that is all it displays?
Users browsing this forum: Apple [Bot], Majestic-12 [Bot] and 51 guests
