 Post subject: Nexus dock not being activated
PostPosted: Sun Feb 24, 2008 8:40 pm
Under Nexus Dock properties, I have selected under ACTIVATION, Bottom Screen Edge. It used to be that when I had a window open & maximized (thus covering my Nexus Dock), I could get the Dock to come to the foreground simply by hitting the bottom screen edge with my mouse cursor.
This is no longer working. Any ideas as to why? Thanks.
John
PS My Dock is positioned along the right screen edge & centered vertically.
PostPosted: Tue Feb 26, 2008 7:19 am
John, have you tried other screen edges to see if the activation works there? I just tested it and it seems to be working fine here...
PostPosted: Tue Feb 26, 2008 1:34 pm
I have!!! Does not work. This stopped working prior to Extreme 8.2.
John
PostPosted: Wed Mar 19, 2008 3:37 pm
Jorge:
This still is not working: a real mystery since it worked fine up until recently!
Any further ideas?
John
PostPosted: Fri Mar 28, 2008 2:46 pm
Jorge:
Hello? Anybody home? :D
John
PostPosted: Fri Mar 28, 2008 3:08 pm
Hey John!
Yes, somebody's home, and this was fixed yesterday :D (read the 8.2 problems thread). Pete pointed me out in the right direction because he managed to connect the action of disabling WorkShelf's edge bump (either via Prefs or the systray icon) to NeXuS not activating anymore.
This is the problem with bugs (and why I wrote this article HERE) - sometimes they are connected to settings or conditions specific to your system and, unless you do some of the leg work yourself and find a pattern or a way to reproduce the problem, it will be very difficult for me to connect the dots.
Users browsing this forum: Amazon [Bot], Apple [Bot], DuckDuckGo [Bot], Google [Bot] and 68 guests
