 Post subject: Can it be done
PostPosted: Sun Feb 03, 2008 9:05 pm
The other designer I work with has a Mac. I still prefer my WinStep setup, but one thing that I think is very cool on the Mac is the ability to have a hotspot that will tile all open windows on your screen allowing you to click on the one you want to be on top. Can that be done in WinStep?
And if not, when will it? ;)
http://www.scarebear.org/
PostPosted: Sun Feb 03, 2008 9:45 pm
That 'thing' has a name: Expos?. I think you can find a number of Expos? clones for the PC if you search the web... :wink:
PostPosted: Mon Feb 04, 2008 12:47 am
But then I'd have to do something ;)
I'll go search :) It better play nice with WinStep or it's gone :)
Users browsing this forum: Apple [Bot], Google [Bot] and 67 guests
