Board index : Winstep Forums : General Discussion  [ 18 posts ] Go to page Previous  1, 2
 Post subject: Re: PWA's
PostPosted: Mon May 18, 2026 9:29 pm
Ahaha priceless...
Anyway, here is a trick to get it to work until I fix that: instead of launching the Chrome shortcut in the dock with the left mouse button, launch it with the middle mouse button.
Another alternative is to right click the Chrome shortcut, select "Dock Entry Properties" in the right click context menu then enable "Allow multiple instances".
Also, can you please try pinning a PWA to the dock, and then making sure you can launch it again from the pinned dock shortcut?
PostPosted: Tue May 19, 2026 5:12 am
kuball11 wrote:
Soooo close, all the individual PWA's work really well now. However, when I try to open Chrome itself it only opens or minimizes the last PWA I was working with. It does not open the chrome browser.
Ok, I fixed it. Just download the beta again from the same link as before, then please let me know.
PostPosted: Wed May 20, 2026 5:01 pm
I will never doubt your skills sir. It all works as expected now. Thank you so much.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 18 posts ] Go to page Previous  1, 2
Users browsing this forum: Apple [Bot], Google [Bot], GPT [Bot] and 37 guests
