 Post subject: Clock module
PostPosted: Sun Jan 27, 2008 8:00 pm
When I click on "check atomic clock" from the Clock Module R-click menu, nothing happens & the time showing in the Clock Module (& in the tray clock) is incorrect. What gives? Thanks for help. I am using most recent beta (I believe this problem has been around for some time).
John
PostPosted: Mon Jan 28, 2008 12:21 pm
What does the clock balloon tooltip say about the last time the clock was successfuly checked? Also, you're NOT running under Vista already, are you?
PostPosted: Mon Jan 28, 2008 3:07 pm
Jorge:
I'm not using Vista (& hope never to use it). The tooltip says it was last checked yesterday & that the clocks matched!!! Today, the time is correct!!!
This all makes little sense.
In addition, is there a way to sync the tray clock in NextStart if I am not running the clock module?
Thanks.
John
PostPosted: Mon Jan 28, 2008 3:18 pm
Indeed!
No, NextSTART does not provide that functionality, only WorkShelf. You don't need to have the desktop clock module open, though, all you need is to have an in-shelf or in-dock clock module open.
Users browsing this forum: No registered users and 15 guests
