Board index : Winstep Forums : General Discussion  [ 573 posts ] Go to page Previous  1 ... 27, 28, 29, 30, 31, 32, 33 ... 39  Next
PostPosted: Thu Jan 15, 2026 12:31 pm
Most are done minus tweaking and one has a different graphic when I get around to it...
Easier to put up a disk drive collage.
PostPosted: Thu Jan 15, 2026 12:48 pm
And another
PostPosted: Thu Jan 15, 2026 2:26 pm
PostPosted: Thu Jan 15, 2026 4:27 pm
BOOM
Water drive, Earth rings - this one I am putting the model#, file system and drive letter where the graph usually goes in the vertical. I have an external Ext4 and HFS disk. Will be interesting to test. I have Macdrive so Windows will see it.
More farting around with pads, tiles, disk widths and heights than any other theme to get it to look how I envisaged it.
PostPosted: Thu Jan 15, 2026 4:54 pm
PostPosted: Thu Jan 15, 2026 6:36 pm
The whole enchilada in this one BUT only one graph, the one that relies accurately on your performance monitor..
The Horizontal looks best with the disk and the vertical with the ring (to me) - each to their own.. Why I prefer it is because the drive letter flashes inside the ring when there is disk activity, so that tells you something is happening. It stops when disk activity stops. Minor alignment fixes to do, nothing more.
PostPosted: Fri Jan 16, 2026 1:18 pm
@NEXTER
Only 1 post by the user above me?
- Real or A.I ?
PostPosted: Fri Jan 16, 2026 1:22 pm
And next... will rescale later. Yes the drive and rings were made to be icons. Did not work to my satisfaction, so I changed the concept to purely match the theme aesthetically.
PostPosted: Fri Jan 16, 2026 2:05 pm
Testing the above on 5120x1440 I made a version purely for myself on ultrawidescreen, yes the labels are wrong on the attached piccies.
PostPosted: Fri Jan 16, 2026 3:32 pm
PostPosted: Sat Jan 17, 2026 2:53 am
@NEXTER
- Real or A.I ?
Definitely spam, and most likely produced by AI chatbot for spam bot. Barstewards. :|
Anyway, killed it. :)
PostPosted: Sat Jan 17, 2026 3:03 am
PostPosted: Sat Jan 17, 2026 6:24 am
PostPosted: Sat Jan 17, 2026 1:29 pm
These are not in the current icons file. Will be in the next. Still another 19 after this to finish.
PostPosted: Sat Jan 17, 2026 1:39 pm
all disk drive modules with added graphics are tested with only one drive to ensure nothing gets chopped off. :)
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 573 posts ] Go to page Previous  1 ... 27, 28, 29, 30, 31, 32, 33 ... 39  Next
Users browsing this forum: Bing [Bot], Picco14 and 55 guests
