 Post subject: How to use the Winstep Email Checker with Gmail Accounts
PostPosted: Tue Jun 10, 2025 7:36 am
Google discontinued “Allow less secure apps” in May 2022, which caused the Winstep Email Checker module to stop working with Gmail accounts using the old username + password method.
However, you can still access a Gmail account using the Email Checker module with a username and password**, but **only if** certain settings are configured correctly. Here's what you need to know as of 2025:
POP3:
Requirements for POP3 Access
1. Enable POP in Gmail Settings
* Go to **Gmail > Settings > See all settings > Forwarding and POP/IMAP**
* Under **POP Download**, select:
* “Enable POP for all mail” or
* “Enable POP for mail that arrives from now on”
* Save changes.
2. Enable 2-Step Verification
* You **must** have 2-Step Verification enabled on your Google account to use App Passwords:
* Go to: https://myaccount.google.com/security
* Turn on **2-Step Verification** if it's not already enabled.
3. Create an App Password
* Visit https://myaccount.google.com/apppasswords
* Select "Email Checker" as the app and your device (or “Other”).
* Google will generate a 16-character password.
4. Use This App Password in the Email Checker module
* Username: your full Gmail address (e.g., `you@gmail.com`)
* Password: the **App Password**, *not* your Google account password!!!
POP3 Server Settings
Use these settings in the Email Checker:
POP Server: pop.gmail.com
Port: 995
Requires SSL: Yes
Username: Your full Gmail address
Password: **16 character App Password** (not your normal password)
IMAP:
Requirements for IMAP Access
1. Enable IMAP in Gmail
* Under **IMAP Access**, select “Enable IMAP”
* Save changes.
* Visit: https://myaccount.google.com/security
3. Generate an App Password
* Go to: https://myaccount.google.com/apppasswords
* Choose "Email Checker" as the app, and “Other” for the device if needed
* Use the generated 16-character password as your login credential
IMAP Server Settings
IMAP Server:imap.gmail.com
Port:993
Requires SSL: Yes
Username: Your full Gmail address (e.g. `you@gmail.com`)
What No Longer Works
* You **cannot** use your regular Gmail password for POP3/IMAP/SMTP access if:
* 2-Step Verification is not enabled
* Less secure app access is disabled (which it is by default since mid-2022)
* Google discontinued “Allow less secure apps” in May 2022.
 Post subject: Re: How to use the Winstep Email Checker with Gmail Accounts
PostPosted: Thu Aug 28, 2025 9:32 pm
Yes it is painful setting it up in Gmail.
As the Winstep creator, is there a moderately secure email that it sets up with a minimum of fuss? Or, are they all pretty much the same these days - e.g. Protonmail so on and so forth...?
If I knew the answer I would not ask. I figured as the creator you'd know the one that works immediately, if it exists.
Thank you :)
PostPosted: Fri Aug 29, 2025 12:52 am
I don't.
As you can imagine the process is different for each email provider.
PostPosted: Fri Aug 29, 2025 12:57 am
Thank you :)
There is no such thing as a moderately secure email service - they are all totally insecure. Sole exception is Proton Mail (available free and also enhanced paid version) which is End-to-End encrypted with zero access (i.e., only you can access your mail box and mail, not the provider or anyone else). It's available as a web app (even works with TOR browser), and as a desktop app for all platforms inc. mobile. And there's no logging of any kind. Proton wants to know as little as possible about you. :D And it's all on Proton's own hardware, securely running Linux.
I would have thought that email checkers are totally obsolete in this day and age. I get notifications - i.e., the number of new mails, on my Proton web mail's task button - what more could I want? :)
Now, without wanting to anticipate Jorge's reply, I would have thought that if there was another email service that could be easily - or at all? - set up with the Email Checker module we would have heard about it already.
PostPosted: Fri Aug 29, 2025 6:19 pm
I don't.
Thanks Jorge, I thought as much, but always best to be sure.
@Nexter - Rather than bulk replies, yes, checkers are almost obsolete. Most people carry it in a phone app etc...My only reason for wishing it is to check what displays on the screen in real-time for realignment in the module if necessary. There is mail.com but I am a little sus of that one.
Thanks both of ya...
PostPosted: Sun Aug 31, 2025 4:06 pm
It's not only Mail.com you need to be sus about - you ought to be totally sus, nay, paranoid even, about all email providers with the sole exception of Proton. Everybody else harvests all your data mercilessly, usually including the content of both all your incoming and outgoing mail, sells on your data, bombards you with ads and trackers, and is likely to be hacked and lose your data and email. None of this can happen with Proton. If you want security and privacy, it's your only choice, alas. The rest aare as dodgy as a 9-bob note! :P (And you would not accept one of those, surely!)
PostPosted: Fri Oct 17, 2025 2:23 pm
I setup gmail with imap according to the instructions and even set up an "app password" in gmail. Now it says "Too many arguments provided".
Any ideas?
PostPosted: Sat Oct 18, 2025 1:11 pm
Assuming you are not a spam bot, you must have done something wrong while following the instructions.
My own Gmail account keeps working properly with the Winstep Email Checker (I am using the POP3 protocol in the Email Checker, by the way).
This said, I read somewhere that Google is going to discontinue POP3 access and stick to IMAP only.
PostPosted: Fri Oct 24, 2025 6:49 am
Jorge, I am pretty sure I'm not a bot and I'm getting the same message. In the Email Checker Settings I have
Account Name: [my email address] (firstname.lastname@gmail.com)
Server Type: IMAP Port: 993
IMAP Server: imap.gmail.com
Login Name: [same as account name]
Password: [the 16-digit app password I generated and named "Email Checker" on Google]
Requires SSL is checked
Include this account when checking is checked
Last response was BAD Too many arguments provided 41be03b00d2f7-b6cdac3baadmb217059414a12
PostPosted: Fri Oct 24, 2025 9:35 pm
I find it incredibly hard to understand why otherwise fairly intelligent or even intelligent people (like yourself, @vectornut) still stick with Gmail and Google and give away their privacy for nothing. Not even for 30 pieces of silver! :P
There are perfectly good, privacy-respecting alternatives available, most notably Proton Mail - available in a pretty good free version, too! - which is End-to-End encrypted and not even Proton can access your emails. :?
PostPosted: Fri Oct 24, 2025 9:50 pm
Try using POP3 instead, e.g.
Server Type: POP3 Port:995
POP3 Server: pop.gmail.com
That's what I use and I am not getting an error.
PostPosted: Sat Oct 25, 2025 5:59 am
Will that work when I have gmail set up for IMAP to use with my EM Client?
PostPosted: Sat Oct 25, 2025 8:44 am
Give it a try to at least see if you get the same error.
My guess is that this is a Gmail issue, not a Winstep problem.
PostPosted: Sat Oct 25, 2025 6:09 pm
Switching to POP worked. And I know it's not a Winstep issue. It's definitely a gmail issue. I wouldn't blame Winstep for struggling to overcome a third party app's settings. I know some people would, but that's because they're dumb. The good news is I guess gmail has changed and you can access it with pop or imap and don't have to choose one or the other any more.
The main reason I posted was to let you know that your instructions for getting the email checker to work with gmail no longer work for IMAP on gmail because clearly gmail changed something again.
PostPosted: Wed Nov 05, 2025 4:18 pm
Anyone have any idea on how to use this with Outlook/Hotmail/Live accounts?
I enabled pop/imap in outlook account settings. I tried a Microsoft App Password and my real password.
Tried both IMAP and POP
I get the error "NO LOGIN failed."
I believe this is due to microsoft requiring OAuth2 auth method...though I thought gmail did too but this post suggests that works.
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot] and 33 guests
