Board index : Winstep Forums : General Discussion  [ 197 posts ] Go to page Previous  1 ... 10, 11, 12, 13, 14  Next
PostPosted: Sun Sep 21, 2025 8:17 pm
Makes sense to tidy things up and leave the drive mod for next time. :) Also good news re: the Themes Gallery - it's been waiting long enough! ;) Hope it'll be OK bandwidth wise when it goes live.
PostPosted: Sun Sep 21, 2025 9:13 pm
Yeah, that is my main fear too.
There are enforceable daily download limits, you must be logged in to download and that requires you to create an account in the forums, so perhaps this is enough to keep bandwidth usage under control.
PostPosted: Mon Sep 22, 2025 1:54 am
Hmm, I wouldn't bet on it. :( Always best to err on the side of caution and set fairly conservative limits. And if there's a sudden flood of account creations, you know you're in trouble... ;)
PostPosted: Sat Sep 27, 2025 4:30 am
New final betas, need feedback ASAP:
Nexus free beta:
Nexus Ultimate beta:
Winstep Xtreme beta:
This is a beta and MUST be installed ON TOP of a full v25.7 or later installation. Do NOT uninstall anything first, just exit all running Winstep applications and run the beta setup file.
Nexter, I need you to let me know ASAP if the new beta solves the crashes you mentioned when trying out themes.
Everyone else, I need you to look for problems if possible with stuff related to going into a game and exiting, switching between different multi-monitor configurations (i,e, making sure the multi monitor profiles are working as intended) and stuff staying where it should when the PC returns from sleep, etc (i.e. making sure the reserved screen areas are operating properly).
Also, to get to the new tab colorization feature: Shelf Properties -> Appearance tab -> Tab Color Settings button. Remember the effect depends on the theme and colorization method applied (and on some themes - such as DarkTech for instance, since the tabs are actually transparent - it will have no apparent effect).
This as usual is going to be a very fast final beta (sorry!) since I want to release v25.9 still in September, so I need feedback as soon as possible.
PostPosted: Sat Sep 27, 2025 5:49 am
I'll try to fit it in later today or tonight, Jorge. :)
PostPosted: Sat Sep 27, 2025 6:46 am
1. Tab colour settings for inactive tabs works on a low percentage of my installed themes (about 3 out of 17), although active tab colourisation works on more.
2. You have to play between the different colourisation methods to see what works best for a particular theme (as mentioned above, most of which only work on the active tab). Tone monochrome bitmaps seems to work the most, but not always.
3. No crashes observed while switching / testing themes.
4. The double click issue is still present.
5. Doesn't appear to be any problems with my multi-monitor use - but have not changed profiles (as what I have works for me).
6. Entering / exiting games appears to work fine.
7. Multi-select / delete appears to now work on the Recovery Shelf. Out of interest though - if you select multiple items across different grid stacks / launch pads, only the items in the displayed area are selected for deletion. This means that if you move away from say a grid stack after selecting an item, to another grid stack / launch pad where nothing is selected, then nothing will be deleted. I can see why this is, but it was worth noting.
8. Brief test of multi-select / move functionality appears to work, but I'm afraid I have limited time at the moment.
Will hopefully have a bit more time later.
PostPosted: Sat Sep 27, 2025 8:28 am
Thanks, guys! :D
Hue shift retrieves the dominant color of a particular bitmap and then shifts the colors of the whole bitmap so that the dominant color becomes the target color. Whites and blacks are preserved but the shift affects all the other colors too, of course.
Grays, blacks and whites are not really colors, so bitmaps that do not have a dominant color will basically suffer no change.
Tint first turns the bitmap grayscale (all original color information is lost) then applies a kind of color overlay on top of the grayscale bitmap. Everything gets 'tinted" with the target color, except blacks which are not affected.
Tone Monochrome is the only method that actually affects blacks. Black is RGB (0,0,0) and tone monochrome literally adds the RGB of the target color to the colors of the bitmap. This works well if the bitmap is black & white but makes a mess otherwise.
Not sure I am following this, sorry?
PostPosted: Sat Sep 27, 2025 2:06 pm
It was an attempt to state that the operation of deletion only works with the latest selection - which is understandable, even if it doesn't appear so visually.
eg. If I was to select a couple of items across different stacks as shown in image_1 and then try to delete, then the only item(s) selected for deletion are in the latest (or top) stack - as indicated by image_2.
If there is nothing displayed in the latest / top stack (as in image_3), and delete is pressed, then nothing happens.
As I said I can understand the logic behind this, even though it looks as if a number of items are selected on screen.
I'm trying to decide if it would be better to deselect lower stack items if you select an item in a higher stack, in a similar way to deselect of items if switch between tabs on a shelf...?
PostPosted: Sat Sep 27, 2025 2:22 pm
Ah ok, I think I understand now. The DEL key only has an effect on the Grid Stack that currently has the focus.
PostPosted: Sat Sep 27, 2025 7:13 pm
And done so - gave everything a good half an hour! Post Beta install, everything's just dandy now! :D No problems with anything so far. Haven't tested the tab colourisation yet, but did try multi-del with a test stack, also just fine. Thanks Jorge - sitting tight waiting a few days for the update sure beat messing around trying all sorts for an hour or two! ;)
Back in Linux (the blue hat) now busting my balls working away. ;)
PostPosted: Sun Sep 28, 2025 8:49 pm
Gave the beta a full hour this am! :) Funny thing was, after booting into Windows and starting Xtreme, everything loaded fine but then got a dialogue, something like "Can't find Workshelf..." Anyway, clicked that away and everything was fine. Also tested the Shelf Tab colourisation on a bunch of themes, none of the methods had much if any effect here. Only themes with light solid tabs showed effect, best with hue. Anyway, it''s working without throwing any wobblies. :)
PostPosted: Mon Sep 29, 2025 3:55 am
So far that was only on the B laptop. A while ago was able to go on the A one and set up the beta there. Also everything just fine. The tab colourisation seems to work best with hue, and surprisingly best on most of my own themes despite them having graduated bitmaps! :D
PostPosted: Mon Sep 29, 2025 4:38 am
Thanks for the feedback. I think this beta might actually end up being the final release...
PostPosted: Tue Sep 30, 2025 2:25 am
I guess 25.9 Release delayed by bug? Well, it'll come along when it's ready. Not worried Jorge. Anyway, there certainly hasn't been anything untoward under the beta - as good as a release here. :D (All new features checked out fine on both laptops.)
PostPosted: Tue Sep 30, 2025 4:34 am
Yeah, kind of, as I fixed that docking issue when using more two monitors. I was also finishing the announcements, which was fortunate in this case as it allowed me to include the fix for the docking issue in v25.9.
Anyway, announcements are done, now making sure everything is as it should for the new release.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 197 posts ] Go to page Previous  1 ... 10, 11, 12, 13, 14  Next
Users browsing this forum: No registered users and 59 guests
