Board index : Winstep Forums : General Discussion  [ 197 posts ] Go to page Previous  1 ... 9, 10, 11, 12, 13, 14  Next
PostPosted: Thu Sep 18, 2025 10:53 pm
So, the following is an example of what you can expect with tab colorization. I'm using randomized colors so the look is less than optimal, of course.
The first sample is how the theme looks without tab colorization, the second using hue shift and the third tint (hue shift is more subtle).
Hue shift does nothing on themes with gray tabs (like the one at the very bottom, so for those you must use Tint)
I think this is the type of thing you would use only once you've settled in a favorite theme, so that the colors you choose for the tabs are optimal for that theme. The same sequence of colors might not work so well (or at all) with another theme.
PostPosted: Fri Sep 19, 2025 12:45 am
Continuing from a conversation in 'Winstep Wishlist' which is more appropriate here :) :
Since I'm actually adding tab colorization to the next release, further discussion on this subject should be on the What's next after v25.7 thread... :D
Just following team orders. :P
it could really make an ugly mess of some themes and destroy the whole effect. Dedicated alternative bitmaps sounds the lesser of two evils to me. ;)
You already have full shelf etc colorization if that is your objection. Tab colorization would not work with every theme (e.g. the tabs in some themes have a transparent background as they are "incorporated" into the shelf body, for instance), but on those (few?) themes that it would work, this would at least become an option.
Going for the alternative bitmaps reduces that choice to nill at this point, AND it would make things a lot more complicated for me.
This way the colorization would be a property of each tab (e.g. right click, select Tab Properties) set by the user and NOT a specific theme. Same way global colorization (Shelf Properties -> Appearance tab -> Color Settings button) are currently a property of the whole shelf (set by the user) and not of a theme.
Personally, I just don't like any colourisations, and for that matter, any alterations to a theme that somebody has taken the trouble to create, as stated in the post you quote/refer to. A user should either like it or lump it and pick another one.
I can understand that the multi-tab option would be a lot of work for you Jorge, no doubt about that, and yes, users would have quite a wait ahead for some themes using this option to come along. I just suggested that from a creative point it would be the lesser of two evils. :)
As luck would have it, editing a theme, I had to manually go into Workshelf and change the text type and coloration - It seems you have empty and inactive Button3= , Button4= etc already like a placeholder?
I see both sides here... Honestly if it comes down to user choice, it has often been said that more than two choices should be avoided. One one hand, if you are giving one choice being coloring and no bitmaps, it kind of forces the user into default settings or coloring. If the skinner only creates an active and inactive like it is currently, then nothing changes - However, if in some of the newer themes that 'might' come out, the user has the option of thematic or coloring.
- just an observation ;)
When it comes to user choice, the two choices he should have should be either to use a given theme as is or pick another one. Simple. More than enough choice. :D
All of that said, I know you have far more important things that take precedence and so they should, so if you can do the coloring without taking too much time away, we can always revisit the bitmaps another time :)
P.S - I could have got really convoluted and suggested that if a skinner created 12 different TAB buttons, the user could select their favorite from those 12 as their main TAB :lol: :lol:
LOL! Heck yeah, what the hell why not? ;) :P
@NEXTER - Coloring in different colors I am not huge on either with coloring bitmaps, but it depends on whether it's an actual color change or simply a glow around the buttons, the latter would likely work better.... especially if the user has a color wheel to choose from so they can do variants of the dominant color of the theme they are using and save per theme.
Ouch! Sorry, no, a "glow" around the bitmaps sounds even worse.
Too much choice is never a good thing. For proof of that just look at the sheer madness of our hyper-consumerist society and its consequences. Too many choices everywhere. KISS should be a guiding principle in just about everything. Just KISS - keep it simple, stupid! ;) As I mentioned earlier, two choices are ample for theme users - don't like a theme as is choose another. And even then one could argue that even that is too much already, and that the app's designer should have provided a look and feel set in stone. :P (Which of course applies to the vast and overwhelming majority of apps anyway, thank goodness, good or bad appearance. And most Linux distros don't give the user much if any choice regarding the appearance of the GUI. However, just look at the disastrous number of different Linux distros - and often their many different flavours as well! - and it''s not surprising that the average Joe is bewildered by the choices and often just gives up, alas!)
Bear in mind that the average human is an idiot to put it mildly. The more choices you give him to change a theme the more he's going to f**k up the look, and all in the worst possible taste. Don't forget, if it wasn't for bad taste a hell of a lot of people would have none at all! :P
PostPosted: Fri Sep 19, 2025 12:49 am
Few themes are that plain and simple though. In any event, I just don't like the whole thing so I'll just keep shtumm on it hereafter. :)
PostPosted: Fri Sep 19, 2025 3:33 am
I completely disagree with this. I think users should have total liberty to make variations of an existing theme (and isn't that how almost every skinner started?) provided he doesn't go public with it and try to pass the forked theme as his own (unless he has written permission from the original theme author and gives proper credit, of course).
This is no different.
Besides, doing this through different tab bitmaps has zero advantage since the actual bitmaps would all be the same, the only variation would be the color - the application is just saving the theme author the work of re-coloring the bitmaps in Photoshop himself, and providing a larger choice of potential colors and colorization methods while doing so.
Again, for me the main advantage is a functional one, it's much faster and easier to locate a specific tab by color than by the title, especially if you have a shelf with a ton of tabs (mine has 22, for instance lol although I normally only use a small subset of those)
PostPosted: Fri Sep 19, 2025 3:46 am
Ahah, sorry, in retrospect I recognize it was indeed phrased more like an order than a request, but that was not my intention. My toddler was playing here in the office while I was typing that and I had to hit Submit quickly as he was forcefully requesting my full attention lol
PostPosted: Fri Sep 19, 2025 5:06 am
LOL! Whoa, nah, don't fret Jorge, I didn't mean that I took it to be an 'order', relax my friend. :) It was meant humorously, nothing more.
Looks like the little fellow's got you wrapped around his little finger! ;)
PostPosted: Fri Sep 19, 2025 5:18 am
Not that I'd compare any theme to a great work of art per se, but all the same, altering a theme in any way to my way of thinking is like trying to improve the Mona Lisa - and you're likely to end up by adding a mustache! ;)
But of course, I also see your point, Jorge. And I wouldn't even consider asking for multi-tabs in earnest. :) I think the maximum number of tabs I ever used might have been about 7, BTW.
PostPosted: Fri Sep 19, 2025 6:38 am
I think that it will depend on the theme.
I have no issue with applying different colours to different tabs, provided you can choose what they are - this could enable grouping of associated sets.
However the ability to see which is the active tab is key - in some of the pictures above it is not immediately obvious which tab is active.
PostPosted: Fri Sep 19, 2025 7:05 am
If by multi-tabs you mean multiple tab lines on the workshelf, probably with each tab set offset from the one above (similar to folders in a filing cabinet drawer, or a card deck), then I could see the benefit of that if you have a lot of tabs!
My workshelf has 11 tabs, and I could possibly add another one without ruining readability (this is on a 24" monitor at 1900x1200 with a reasonable size font - for me). I can't imagine how Jorge has 22 unless he has a huge, high res monitor, with relatively small text (unless he has very small tab descriptions - and even then!). So in that sort of case I could see how multiple tab lines would be useful.
However I suspect that this would involve a lot of effort - to either reskin themes, or to come up with a method to allow the themes title bars to be replicated and shifted. Not even sure if that is possible (as I don't know much about creating / skinning themes) - so you would be back to effort on both fronts.
PostPosted: Fri Sep 19, 2025 7:20 am
I agree. But mostly because you don't know the themes. In those examples the active tab is actually NEVER colorized. I'm still debating whether to keep it like that—it really depends on how much the colorization affects the ability to identify the active tab. Perhaps I will simply add this as an option.
Two 43" 4K monitors at 100% DPI (one IPS the other OLED).
I literally wrote three (!) lines of code to implement this new tab colorization method, the one that generated the tab colorization examples above. That's why I jumped on this idea so quickly, it's low hanging fruit for me. Low effort, high reward.
What will actually take longer is adding the dialog with the new settings for this. The code that makes all this work is basically already there, so far used for other stuff.
Below is the wire frame mockup for this dialog after throwing ideas around with CoPilot about it (forget the Reset and Apply to All features though, not planning on using that). Besides this dialog, each Tab Properties dialog will also have a color well for that tab so you can change it there directly too (although the actual colorization method can only be set in the dialog below).
Code:
|                Tab Colorization Settings                    |
|     Customize tab colors and preview your shelf in real time|
[ Colorization Method for This Shelf: [Dropdown ▼] ]   ← None / Hue Shift / Tint
| Tab Colors                                                  |
| | Tab Name       | Color Swatch   | [Reset]               | |
| | Tab 1          | [■]            | [Reset]               | |
| | Tab 2          | [■]            | [Reset]               | |
| | Tab 3          | [■]            | [Reset]               | |
| [Apply same color to all tabs] [■]                         | ← Optional bulk action
| Shelf Preview                                               |
| [ Live rendering of shelf with themed background ]          |
| [ Tabs shown with selected colors and method ]              |
| [Toggle: Show theme background □]                           |
| [Apply]   [Cancel]   [Reset All]                            |
PostPosted: Fri Sep 19, 2025 11:46 am
When you have two monitors (as I do) then you can just have a separate workshelf on the 2nd monitor, with different tabs - but to be honest I prefer to just keep one shelf on my main monitor.
Thats really good / lucky.
However when I was talking about a lot of work, I was referring to the implementation of a multi-tab line capability.
The wireframe mockup looks good - will be interested in seeing the implementation.
PostPosted: Fri Sep 19, 2025 4:35 pm
No, sorry, I used 'short hand' multi-tabs referring to multiple tab bitmaps which were being discussed there. :)
PostPosted: Sat Sep 20, 2025 7:29 am
Here you go:
PostPosted: Sun Sep 21, 2025 5:56 am
Here you go:
PostPosted: Sun Sep 21, 2025 6:35 am
I think I am going to start tying the loose ends (double click issue, etc) and leave the Drive Monitor module for next release. There is already a ton of new stuff in this version and it will be something I can start working on immediately after v25.9's official release.
Especially because modules sometimes take an exceptionally long time to get right: I remember when I decided to add a Moon Phase module because I wanted to make a quick addition and I thought it would be a fast "5 minute" job. Man, did I go down a rabbit's hole on that one, lol!
Back then there was no AI to help you and I had to learn a ton of new obscure stuff about the moon that I didn't even know existed eheh. Getting the formulas just right so that I could look out the window and see the real moon tilted exactly like the one in the module (the angle you see the shadow of the moon - for instance - depends among many other things on your location on earth, etc), and at the expected angle above the horizon, was a mammoth task.
Dynamically creating the shadow of the earth on the moon in a way that looked both good and realistic AND was fast enough to smoothly animate the moon in real time in the Moon Calendar dialog was also a challenge. A fun one, but still a challenge lol
I think of all the modules, the Moon Module was ironically the one that took longer to get just right. 5 minute job indeed lol
Anyway, something else I want to tackle after the v25.9 release is the Winstep Themes Gallery. Pretty sure the AI will be able to help me with the Code Igniter/PHP code in which the web developer coded the current version (it's so bad his code has zero comments!) and I already have a few AI generated mockups on visual and functional improvements to the current Gallery. I'll open a topic on the subject when the time comes.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 197 posts ] Go to page Previous  1 ... 9, 10, 11, 12, 13, 14  Next
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Google [Bot], GPT [Bot] and 42 guests
