Board index : Winstep Forums : General Discussion  [ 32 posts ] Go to page 1, 2, 3  Next
 Post subject: System tray icons disappeared with latest build
PostPosted: Sat Aug 16, 2025 12:04 am
I have just updated to 25.7 but unfortunately that means I can no longer see my System Tray icons. They were there in the previous build. I run ExplorerPatcher, which allowed Nexus to show them.
I can live with an earlier build if that means I can see the icons. So assuming the latest build has changed something that I can't alter, is there somewhere that I can download a previous build? I can't remember which one I was on but I assume it was 24.6 or whatever the last one was.
 Post subject: Re: System tray icons disappeared with latest build
PostPosted: Sat Aug 16, 2025 4:01 am
As you know from Windows 11 22H2 forward Microsoft moved the tray to XAML islands and removed legacy code that still allowed 3rd party applications to access the tray icons.
I added a work-around, a cog icon that would give access to the tray Quick Settings Panel, but that is way less than optimal, as it is not the same as having the major system icons visible, i.e. the net, volume and battery icons.
As a result in v25.7 I added fully functional "clones" of these tray icons. Since it was official that Windows 11 22H2 no longer allowed access to the tray icons, to save CPU cycles I did not even bother trying.
And so I completely forgot about "hacks" such as Explorer Patcher.
Instead of reverting to the previous version, give me a couple of days and I'll come up with a beta that restores access to the system tray icons if Explorer Patcher (or anything like that) is installed.
PostPosted: Sat Aug 16, 2025 7:52 am
Ok, should have already fixed it here, I'll let you know as soon as the beta is available for download.
PostPosted: Sun Aug 17, 2025 2:34 am
Ok, since you are running Nexus Ultimate, download the v25.8 beta from HERE, exit all running Winstep applications, unzip and run setup.
Please let me know if that fixed the problem of original tray icons now showing despite ExplorerPatcher being installed.
PostPosted: Thu Aug 21, 2025 12:59 am
It's very good of you to respond so quickly. Thanks for that.
Unfortunately the system tray hasn't appeared. You can see in the screen shot that I still just see the blue dot (the Nexus bar is on the left side).
I've rebooted. And I've tried creating a new dock that shows the system tray, but same outcome. Anything else I should try?
PostPosted: Thu Aug 21, 2025 4:04 am
It is important to provide feedback equally as fast.
If I am in the middle of adding stuff to a new release (as I am) I can't simply pause everything waiting for you to reply to know if a fix worked, and there will be times when doing structural changes to the code that it will be unfit to a public release of any type for a while.
Yes, I can see it is still using the "replacement" system tray.
I don't use Explorer Patcher. I assumed that if it was indeed working when the Winstep application queried Explorer about the number of icons in the systray it would return something other than 0.
If it returns 0 the application assumes it is running under a version of Windows 11 that does not allow tray icons to be retrieved anymore (and that Explorer Patcher is not running either) and uses the "clone tray" version instead.
I'll look at the code again to see if I might have done some mistake, but in the mean time please post a screenshot of what your real system tray looks like in the Windows taskbar (together with the tray expansion area, the pop up you get when you click on the blue arrow in the dock and in the up chevron in the taskbar)
PostPosted: Thu Sep 04, 2025 12:15 am
Fair enough. Apologies for being slow. You may have had to move on from this now, but I'll check back in daily for a couple of weeks just in case you are able to fit it in. Holiday season is over now.
Screenshot of my system tray is here:
PostPosted: Thu Sep 04, 2025 2:48 am
Good to see a Proton VPN (and MAIL?) user here for a change! Well done. 8)
PostPosted: Thu Sep 04, 2025 7:11 am
Good, since the purpose of betas is to get feedback on new features and fixes lol
I think I figured out at the time what the issue was. Putting the finishing touches on some stuff and should have a new beta ready soon.
PostPosted: Thu Sep 04, 2025 8:40 pm
Well that's excellent news. I'll be looking out for that beta. Thanks for not abandoning me for being slow!
@nexter yes, Proton all the way. It isn't perfect, but I
like it.
PostPosted: Thu Sep 04, 2025 9:34 pm
No worries... but as punishment you will have to help me test the new multi-select feature that allows you to select (and drag & drop) multiple shelf items at once (just make sure to backup your settings first!).
Deal? :D
Nearly finished with it!
PostPosted: Fri Sep 05, 2025 12:55 am
like it.
No, perfect it certainly isn't, alas. Especially not if like me you're a - mainly/85-95% of time - Linux user! :evil: But, it's the only secure, fully private, open source software available at present. (The prices are starting to get a bit rich, too.)
PostPosted: Sat Sep 06, 2025 12:40 pm
Download the v25.9 beta of Nexus Ultimate from HERE, exit all running Winstep applications, unzip and run setup.
Please let me know if this solved the problem and give the multi-selection feature a try please (don't forget to backup your settings first!!!).
You can multi-select items in a shelf in pretty much the same way you would do that in an Explorer window (including CTRL + A to select everything, CTRL + click to toggle select a single item, SHIFT + click to select multiple items, and drag selection over multiple icons (make sure the selection starts from inside the icon grid though).
PostPosted: Sat Sep 06, 2025 4:33 pm
Alas, tied up in Linux for the next few days or more trying to earn my little pocket money but I'll try to sneak into Win to give it a spin if/when I can.
PostPosted: Sat Sep 06, 2025 4:57 pm
That link is for Nexus Ultimate only, which is what he is using... and requires a previous v25.7 Nexus Ultimate full installation.
I should do a proper public beta for Nexus Ultimate and Winstep Xtreme in the next few days.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 32 posts ] Go to page 1, 2, 3  Next
Users browsing this forum: Apple [Bot], GPT [Bot], venkum and 47 guests
