 Post subject: Clock Module
PostPosted: Wed Jul 30, 2025 8:13 pm
I just Okay'd the Nexus Ultimate update to 25.07. As a result the clock changed. I can no longer read the analog clock because the hour and minute (and second) hands are too short. After another software update scream, I figured out how to change the clock from analog to digital. I still can't read the am/pm label. Why'd the analog clock hands become smaller/shorter. I'm older and can't read the darned think. Increasing the size isn't a pleasant option because it disturbs other viewable items. :-(
 Post subject: Re: Clock Module
PostPosted: Wed Jul 30, 2025 8:49 pm
I understand exactly how you feel. Like I (and I'm sure thousands if not millions of other Samsung smartphone users) felt when Samsung (or Google, not sure) decided to change the battery percentage in One UI from nice round fat numbers to something nobody over 40 can understand much less read.
I did not make the clock hands smaller, I just made them use bitmaps instead of the hands being drawn, so it looks a lot better. Never occurred to me someone might have trouble seeing the time now, so sorry about that.
Since scaling the module up is not the solution, perhaps the alternate digital clock style (the one that does not have the calendar) would help? Select Digital style, then open the clock module settings. Look for the digital clock image and next to it enable "Show time only". See if that helps.
If you already tried that, a suggestion is to use 24 hour clock format, that way you do not need AM/PM.
Yet another option is to try and apply different themes to the clock (select analog style, right click the clock -> Themes). See if one of the themes has big fat clock hands.
PostPosted: Thu Jul 31, 2025 2:07 am
I tried the theme suggestion and that worked okay. Not as good as previously but workable. I couldn't figure out the digital setting for 24 hours but really don't want to go there as I have to convert all afternoon and evening times. The world seems to hate older people, at least technology does. :-(
PostPosted: Sun Sep 21, 2025 5:39 pm
You might like to know that In the upcoming v25.9 release I’ve added an option to render the analog clock hands using the previous drawing method.
PostPosted: Sun Sep 21, 2025 8:10 pm
Yeah, that is good news, and I'm sure not only for the OP and myself, there must be others with similar problems too. In some themes they turn out too small, in others just not clearly visible, and so on.
PostPosted: Sun Sep 21, 2025 9:10 pm
This is why I don't like to deprecate features, no matter how obscure and how much I think nobody is using them. The truth is that there is always someone out there relying on it.
The drawback of this is settings creep.
PostPosted: Mon Sep 22, 2025 2:03 am
Alas, there's always a flip side to everything... :(
In this particular case, it's a small price to pay compared to the other solution - separate hands bitmaps for the iconic module and the required settings! :D
Users browsing this forum: Apple [Bot], Majestic-12 [Bot] and 51 guests
