 Post subject: Shortcuts in folders dont work
PostPosted: Wed May 14, 2025 2:29 am
Hi guys!
I made a folder containing shortcuts on my desktop. I drugged this folder in Nexus. From its properties, I set it to open as a menu. It appears correct but when I click on a shortcut nothing happens.
It used to work fine but for some reason, it doesn't anymore.
And this feature is the one I need most from nexus.
Can anyone help?
 Post subject: Re: Shortcuts in folders dont work
PostPosted: Wed May 14, 2025 3:03 am
Basically that is the problem. If it used to work and suddenly it doesn't anymore, what changed in your system in between?
Are you using an Insider version of Windows? Are you running other 3rd party Windows customization tools that might interfere with Winstep?
Also, you are flagged in StopForumSpam as a spam bot. And I bet you are one too.
PostPosted: Wed May 14, 2025 8:49 pm
Ah well, haven't we seen it all before! "Illegitimis non carborundum, George" - Don't let [the] bastards grind you down, Jorge. ;) (Mock Latin, found in one of Eric Partridge's books while brushing up my Latin when I was a youngster. :D )
