 Post subject: universal apps icons
PostPosted: Tue Apr 29, 2025 11:14 pm
so, my universal app icons are gone. rebuilding the cache and restarting explorer/winstep is not working... and thoughts on this? not a deal breaker, just annoying :-) (i blame microsoft....)
 Post subject: Re: universal apps icons
PostPosted: Wed Apr 30, 2025 12:44 am
Same here !! 24h2
PostPosted: Wed Apr 30, 2025 2:09 pm
I'm also running 24H2 and I see no problem with the UWP app icons here.
Are you guys running Insider versions or installing Preview updates?
Also, what icon are you getting for the UWP apps? The Question mark icon?
PostPosted: Sat May 03, 2025 1:02 pm
Im getting the blank white "page" icon. I was able to find a work around by going into the universal app folder (PITA, BTW) and searching for a *.png and choosing that as an icon. I as well am running stock 24h2.
PostPosted: Sat May 03, 2025 3:11 pm
Are you running Stardock's Icon Packager? IIRC, the "blank page" icon was caused by IP.
There is even an entry in the Winstep FAQ about it:
Q) Icons display the default (blank page) image.
A) This is a bug with Stardock's IconPackager. Open the Windows Registry Editor, go to HKEY_CLASSES_ROOT\exefile\shellex and see if the subkey 'IconHandler' exists. If it does, delete it then reboot.
OR it is indeed a problem with Windows itself, as UWP apps don't actually use ICO files.
PostPosted: Sat May 03, 2025 8:13 pm
ok, the reg key does not exist. so... win 11 bug. no biggy, i think I'll just look for icon libraries and pick some.
PostPosted: Sat May 03, 2025 9:08 pm
I am running the latest insider release preview, I don't use that star dock software but I will check for the reg key, attached are images of what windows app icons look like, they do still work but the icons are broken. using a 3rd party icons does work on the dock but it still shows as a blank page on the open application tab.
PostPosted: Fri May 09, 2025 4:55 am
It seems that the Windows 11 KB5055627 update — the *preview* of this KB was released in April 2025 — has been associated with issues where universal (UWP) app icons appear blank or missing on the desktop and taskbar.
What's Causing the Blank Icons?
This update introduced changes to how Windows handles icons for packaged apps. Specifically, Microsoft updated the logic so that desktop shortcuts for UWP apps no longer display an accent-colored backplate, aiming to make icons clearer and larger. However, this change has inadvertently led to some users experiencing blank or white icons for these apps, especially after rebooting or creating new shortcuts.
So, this issue does not seem to be specific to Winstep applications and seems to be due to yet another change made by Microsoft. Whether the blank icons are a bug or by design remains to be seen. We will have to wait until this Patch Tuesday (May 13th) for KB5055627 to be officially released (I know better than running Microsoft "previews" of anything in this day and age), so I can have a look at what is going on and see if I can come up with a work-around (or even if one is necessary/possible).
PostPosted: Fri May 09, 2025 11:46 pm
Nothing is ever a bug in Windows updates, it's a new design feature. ;) :P
There's one of the major differences with Linux. If there is any sort of problem - be that a bug or a security issue or anything else - we get an update within hours that corrects the problem. :D In Windows, you have to wait a month (of Sundays sometimes!) and then you get Gigs of shite coming down the line. :twisted:
PostPosted: Mon May 12, 2025 7:35 am
I was getting the icon of UWP apps using SHGetFileInfo, and in a move preemptive to tomorrow's Patch Tuesday I also added an alternative method (using IShellItemImageFactory). If both fail then this is a core bug in the upcoming Windows update and there is nothing I can do until Microsoft fixes it.
Let's wait and see...
Again, let this be a warning. Nothing good these days comes from installing *previews* of *anything* from Microsoft, ever since they fired their whole QA department years ago, *we* are their guinea pi... err, QA department.
PostPosted: Mon May 12, 2025 3:08 pm
Well, even in the good old days of NT4 - XP, received wisdom used to be never get any updates straight away, wait a few weeks instead (that was when you could still choose whether or not to install updates). And that was before the guinea pigs with previews ever came along as the "QA Dept." :P
PostPosted: Tue May 13, 2025 8:17 pm
One more reason to NEVER install "preview" updates:
Apparently the update that is going to be/has been released today (May 13th Patch Tuesday) only includes the security updates that were part of the kb5055627 preview released on April 25, and doesn't include any of the "new features" (e.g. the changes made to the UWP App icon logic).
As such, I will not be able to reproduce the issue here (which means I cannot come up with possible work-arounds either). Since this apparently also breaks UWP app icons on the Windows desktop, I expect Microsoft will consider this a bug and will fix it sooner or later. The problem is if they decide to do it "later", as recently "later" for Microsoft can mean several months (or worse).
If you guys want to understand how bad and out of control things have gotten lately inside Microsoft, please feel free to read the following The Register article:
OS-busting bug so bad that Microsoft blocks Windows Insider release
"However, it demonstrates that Microsoft has at least some quality gates to stop severely broken Windows releases from reaching Windows Insiders (let alone the broader user base) with bugs so bad that the operating system is rendered unusable."
I can't stop laughing at this, that is not something you want to brag about, that is the bottom-of-the-barrel absolute bare minimum you can do when working on a OS used by billions of people worldwide.
PostPosted: Tue May 13, 2025 11:30 pm
Apparently the update that is going to be/has been released today (May 13th Patch Tuesday) only includes the security updates that were part of the kb5055627 preview released on April 25, and doesn't include any of the "new features" that were also part of that cumulative update preview (which includes the changes made to the UWP App icon logic).
:lol: :lol: Same here, how hilarious! The expression "SNAFU" - System normal, all f*cked up - could have been invented for Mickeysoft nowadays. What a f-up, what a mess!
It reminds me also of the giant mess that revolves around Windowblinds, and an old post here by yourself Jorge - https://forums.winstep.net/phpBB2/viewtopic.php?p=18658#p18658. The number of people I've encountered who tried it and had their registry completely f***ed up I can no longer count on all my fingers. Incidentally, Neil Banfield originally developed Windowblinds - can't remember whether it was called that at the time - on and for OS/2. Although it was a bit more limited, at least it worked flawlessly then. But of course, Windows is a completely different beast... The fact that Windowblinds works at all, if after a fashion, is a real credit to Neil Banfield's abilities, and I rather suspect that poorly constructed skins may well be at least in part responsible for the problems with Windowblinds.
What you said in above post re: skinning Windows Jorge, could equally be said about Windows as a whole post-Win 10 - a bloody nightmare!
PostPosted: Sat May 17, 2025 4:18 pm
Ok, have some good news and some very bad news...
I was doing some experimentation here to try to lower the vCore used by my 12900K and used a value that was too low. When running Prime95 to test for stability, the PC simply rebooted without warning.
I'm telling you this because the unexpected reboot (not even a BSOD, instant reboot) triggered *something* in my system: once I got back into Windows, the icons of UWP apps in the Windows desktop no longer had the solid background, and the icons of UWP apps in the Winstep application were now showing the infamous blank pages/ generic icon described above.
What I think happened is that until the crash my system was still using the UWP app images in the old Windows icon cache. After the crash Windows must have rebuilt the icon cache and this is the result.
So the good news is that I could finally reproduce the issue here.
The very bad news is that BOTH the API methods I can use (GetFileInfo and IShellItemImageFactory) return the same blank page generic icon.
An alternative would be to accessing the app's package resources directly and parse the AppxManifest.xml file that each UWP app has, but alas, Microsoft, in their "infinite Wisdom" (or lack of), prohibit direct access to the C:\Program Files\WindowsApps folder without elevated privileges (and even then I am not sure if you don't have to take ownership of the folder first).
So for now at least I am at a loss as to what to do. Worse, because the Windows shell is apparently using internal methods to successfully get the icons of UWP apps, I seriously doubt Microsoft is going to fix this any time soon.
It's almost like they are trying to break 3rd party customization applications on purpose.
If you know of other applications also affected by this Windows update, please let me know.
PostPosted: Mon May 19, 2025 7:57 am
I would not be surprised if this was actually true (even a friend thought the same), although one should never attribute to malice that which can be explained by pure incompetence.
He did give me an idea, though. It does not solve the problem in any way shape or form, but it might work as a temporary band-aid so users do not immediately run into this problem in the next release with the Windows default UWP apps: I could make a list of those and manually retrieve their icons. I would then bundle these icon images with the next Winstep official release and use these images instead.
In the mean time I think I found proof that this is indeed related to the Windows icon cache: I tried several things with a couple of UWP apps here (so I am not sure what exactly caused it) but suddenly I noticed that the 16x16 icons of those apps would appear properly in the Apps sub-menu of NextSTART (Main NextSTART menu -> Programs -> Apps) while the others still appeared as blank pages. But only the 16x16 versions, dragging those to a dock with a larger icon size still displayed the blank page icon.
I then killed Explorer, deleted all the Windows icon cache files, and restarted Explorer. This forced Windows to rebuild the icon cache, and when I opened the NextSTART Apps sub-menu even those UWP icons that previously displayed properly now appeared as blank pages.
Hmm... as I was writing this, I remembered a post by someone who was having trouble retrieving icons from the Windows icon cache when his application was compiled as 32 bit but not when compiled as 64 bit... as if the architecture of the application had some effect on how the icons are retrieved from the Windows icon cache for some obscure reason. Could it be that Microsoft programmers forgot about 32 bit applications?
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Google [Bot] and 49 guests
