 Post subject: Add browser websites to docks
PostPosted: Fri Apr 18, 2025 2:41 pm
Can I add Browser (Edge or Chrome) websites to the shelves/docks? I currently use Speedial but it seems to be compromising/intercepting my URLs. I don't trust it anymore, but I do love how it looks.
 Post subject: Re: Add browser websites to docks
PostPosted: Fri Apr 18, 2025 4:26 pm
Easiest way is to just drag & drop the URL from the browser's address bar into the dock.
Alternatively you can manually add items (Insert New Item -> Item), select 'URL' type in the dialog box that pops up and type in the URL of the site.
PostPosted: Fri Apr 18, 2025 7:14 pm
Thanks for the fast response!
Pasting the URL worked. As far as seeing a new item pop-up for URL, I don't see that. Here is a screenshot:
PostPosted: Fri Apr 18, 2025 7:36 pm
You select "Item" at the top of the insert context menu, which opens the Item Properties dialog. Then on that dialog you change the 'Item type" to URL, then type in the label and the actual URL and press OK.
Users browsing this forum: GPT [Bot] and 58 guests
