 Post subject: Weather problem: forecast in metric inoperational
PostPosted: Thu Jan 03, 2008 3:13 pm
Help requested! Weather module working fine in Farenheit, but this is of no use to me. Switching to metric in the settings disables the forecasting functions. Current weather is displayed correctly in Celcius however the tool tip forecast appears with no data in it.
PostPosted: Thu Jan 03, 2008 3:24 pm
What are the METAR and Weather.com codes for your location?
PostPosted: Fri Jan 04, 2008 2:34 am
METAR: CYOW
Weather.com: CAXX0343
Thanks for whatever help you can offer.
PostPosted: Fri Jan 04, 2008 4:25 am
Sorry, there is a bug in the current version of Winstep Xtreme that prevents it from reporting negative temperatures in the weather forecast and instead displays them as 'N/A'.
Brrrr... Must be cold there. :wink:
Anyway, I just corrected this problem and the fix will be in the next release... Sorry for the inconvenience. :(
PostPosted: Fri Jan 04, 2008 1:30 pm
Thanks for checking that out so quickly Jorge. Much of the world experiences below zero celcius temperatures so the fix is needed to this useful module. Yeah it's cold here, but I'm enjoying it ... heading out snowboarding tonight! When can I expect this fix/release?
PostPosted: Fri Jan 04, 2008 5:14 pm
Soon, I hope... :D
If you're a registered Winstep user you can always join the Winstep Beta Forums, since updates are generally relased for testing there a few days before being released to the public in General.
PostPosted: Thu Jan 10, 2008 7:36 am
Stein, I gave you access to the Beta Discussion forums. Head over there, a new private beta has just been released which, among other improvements, will also fix the negative weather forecast temperatures problem. :wink:
 Post subject: Celcius Fix
PostPosted: Thu Jan 10, 2008 5:41 pm
Great Jorge, thanks for that!
Users browsing this forum: No registered users and 60 guests
