 Post subject: Winstep with Powershell script and parmeters
PostPosted: Wed Aug 07, 2024 11:57 pm
I've just joined this distinguished forum.
I've looked through the posts and found nothing regarding my issue.
I have a Powershell script (METS_MenuCentral.ps1), a collection of smaller scripts. When I call METS_MenuCentral, I pass a parameter (ie: MySQL_Backup_log). This executes that small section of the PS script to perform that function.
METS_MenuCentral has over 40 of these small scripts all in one place. I have been using this PS script for some time with an alternative software package.
I want to add a dock that will call METS_MenuCentral.ps1 and pass the argument of "MySQL_Backup_Log"
My properties for the dock are:
Item Type: program
Label: MySQL runs Log
Filename: METS-MenuCentral.ps1
Argument: "MySQL_Backup_Log"
Start In: d:\menu
The METS-MenuCentral launches, but I get the warning message generated in my script that no argument was passed.
I've changed the Argument:
1. No quotes (ie: MySQL_Backup_Log)
2. -sectionName MySQL_Backup_Log
3. -sectionName "MySQL_Backup_Log"
and I get the same warning message.
Can any of you folks point in the right direction?
Thank you ahead of time.
 Post subject: Re: Winstep with Powershell script and parmeters
PostPosted: Thu Aug 08, 2024 12:07 am
Hmmm... METS-MenuCentral.ps1 is a script, that is, it is in itself actually an argument to PowerShell.exe.
Try the following instead (no guarantee it will work though):
In Filename use the path to the Powershell executable, e.g.;
C:\system32\WindowsPowerShell\v1.0\powershell.exe
in the Argument field try using instead
METS-MenuCentral.ps1 MySQL_Backup_Log
Let me know if that worked please :D
PostPosted: Thu Aug 08, 2024 12:16 am
Bingo.. give that man a cigar or a shot of tequila or both.
Worked like a charm
Users browsing this forum: Apple [Bot] and 38 guests
