 Post subject: update managar popup notification
PostPosted: Wed May 01, 2024 2:41 pm
Hi - How can I disable update manager pop up notification? It keeps showing the pop up even though I selected never show it again. Thx.
 Post subject: Re: update managar popup notification
PostPosted: Wed May 01, 2024 9:06 pm
Are you sure it's the Update Manager and not the "update subscription has elapsed" dialog? Can you please post a screenshot of the dialog next time it happens?
Users browsing this forum: Apple [Bot], Google [Bot] and 25 guests
