 Post subject: Issue with Nexus Dock on Dual Monitor (2)
PostPosted: Wed Jan 24, 2024 4:52 am
I have a similar, but not identical, issue, so it is better to reopen this thread instead of making a new one. I am using Winstep Nexus Ultimate.
(original thread - https://forums.winstep.net/phpBB2/viewtopic.php?f=2&t=11155 )
I only have a laptop - I move too much to own a PC setup. However, I have external monitors both at home and at work to plug in to. My 2 docks are set to be on the laptop screen, but *occasionally* (maybe once every 2-3 weeks) the second dock will jump to the external monitor. It doesn't take much to set it back in its place, but it is also slightly annoying.
:Moderator's note: That thread really was way too old at almost 4 years, hence moved post to its own topic and inserted link to the old thread. It's always advisable to use a link and start a new topic rather than 'revive' an old one. :/Moderator's note: - nexter
 Post subject: Re: Issue with Nexus Dock on Dual Monitor (2)
PostPosted: Wed Jan 24, 2024 7:24 pm
Does this also happen with v23.11 or are you still running an older version?
Also, what exactly triggers this behavior?
PostPosted: Tue Jan 30, 2024 4:10 am
I'm still running the older version (v22.7). The only trigger I am aware of is plugging in the external monitor, but as I said, it only happens occasionally.
PostPosted: Tue Jan 30, 2024 4:15 am
v23.11 made important changes to how display changes are handled. It's possible (but I cannot guarantee) that this fixed your issue.
Users browsing this forum: Apple [Bot], Bing [Bot] and 28 guests
