 Post subject: do not launch multiple sessions not working
PostPosted: Sat Jan 06, 2024 12:00 pm
i do not know why it isnt working i use opera and opera i linked the dock icon to the shortcut i dont know what is the problem
 Post subject: Re: do not launch multiple sessions not working
PostPosted: Sat Jan 06, 2024 12:54 pm
You **know** it works for other shortcuts in the dock, don't you? Then perhaps you should rephrase the tile of the topic so it's a bit more specific... what do you think? :D
Anyway, can you please post a screenshot of the Docent Entry Properties dialog for that particular item?
Also, does the item get a running indicator symbol after using it to launch (Opera?)
Users browsing this forum: Amazon [Bot], Google [Bot] and 34 guests
