 Post subject: Unknown error beta update
PostPosted: Fri Dec 08, 2023 7:15 pm
I am just reporting a event log I get after a update I received for Workshelf. I have not noticed any performance issues with Workshelf everything seems fine. May be nothing or not, figured just report it and let the expert figure it out LOL
Basic info:
Windows 11 23H2 OS build 22631.2506
WorkShelf.exe 23.11.1469
Winstep.exe 23.11.0118
WSUPDATE.exe 22.05.0202
Event Log:
Faulting application name: WorkShelf.exe, version: 23.7.0.1453, time stamp: 0x64cc72bf
Faulting module name: KERNELBASE.dll, version: 10.0.22621.2506, time stamp: 0xf0ccf8de
Exception code: 0xc000008f
Fault offset: 0x001492b2
Faulting process id: 0x0x1A64
Faulting application start time: 0x0x1DA29F063504A83
Faulting application path: C:\Program Files (x86)\Winstep\WorkShelf.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: 407f153d-7b0b-4a0c-b2ca-77f4c12084e9
Faulting package full name:
Faulting package-relative application ID:
Again not sure if its anything as everything seems fine to me, Cheers!
 Post subject: Re: Unknown error beta update
PostPosted: Fri Dec 08, 2023 7:18 pm
Build 1453 is a beta. Official is already out (build 1469)
PostPosted: Fri Dec 08, 2023 7:26 pm
Yes, Like i was saying just a error when upgrading to the new Official build 1469 I got upgrading from beta 1453 but the update seems to have worked and everything seems fine.
PostPosted: Fri Dec 08, 2023 7:29 pm
Ah, ok, gotcha, thanks! :D
Users browsing this forum: Picco14 and 154 guests
