 Post subject: Unable To Install This Software
PostPosted: Mon Sep 04, 2023 7:22 am
Good morning friends, I just tried to install Winstep in my Windows 11 PC. But I am having a problem when I try to install this software. After completing the downloading process when I install this, I came across this error message "Unknown Software Exception Error Code 0xe06d7363."
I dont know what could be the issue. Could anyone please help me to fix it?
 Post subject: Re: Unable To Install This Software
PostPosted: Tue Sep 05, 2023 7:22 am
After not getting any response, I started searching about this error on Google and came across this guide. Actually it was a Windows error and after following the entire article properly, the problem got solved. Now I have no longer any issues while installing the software and I am working fine on this software.
PostPosted: Tue Sep 05, 2023 4:43 pm
After not getting any response, ....
Geez, how TF quickly did you expect a response!? It's been a mere 24hrs since your initial post! Do yourself a favour please and a) get to know this forum a bit, and b) closely study the following :
https://forums.winstep.net/phpBB2/viewtopic.php?f=2&t=12424
https://forums.winstep.net/phpBB2/viewtopic.php?f=2&t=12445
These should enlighten you a bit about this board and the project. :)
Users browsing this forum: Amazon [Bot] and 61 guests
