 Post subject: Fixing SysTray Problem on Win11 by AutoIt Programming
PostPosted: Thu Apr 13, 2023 2:57 am
Hi,
I recently started using NeXuS and am very satisfied with its abundant Dock customization options, except for the issue of the "Show system tray in this dock" function not working. I found on the forum that this is a problem that all Win11 users will encounter and there is currently no official solution.
However, I often use the sys tray when working, while having both the Nexus Dock and the Windows taskbar simultaneously can be quite cumbersome (and it doesn't look nice too).
So, I researched an alternative solution. For those who may not know: the sys tray can be opened by pressing the Win+B combination keys and then hitting Enter on the keyboard. I happened to know a scripting language, AutoIt, which can simulate keystrokes to the active window using the Send function. AutoIt can also compile the written script into an executable file (.exe), which means you can uninstall it whenever you don't need it.
And most importantly - It's very easy to code the desired functionality with it, as shown below:
Code:
OpenSysTray()
Exit
Func OpenSysTray()
    ; Simulate Win + B to select Sys Tray
    Send("#b")
    ; Simulate Enter to open it
    Send("{ENTER}")
EndFunc
You can install AutoIt, copy and paste the above code into the editor, and then compile it into an .exe file.
Add this file to your Dock item and customize a nice-looking icon - that's it! You can now open the sys tray through NeXuS again!
This is how it works on my PC:
However, I can foresee two potential issues:
  1. I'm not sure if NeXuS' old users will be able to regain as much of their original experience as possible with this method. I have never experienced the original "Show system tray in this dock" function, so I don't know if this function is popping up the original Windows sys tray or reading the system tray information to generate its own 'NeXuS Tray'. This is particularly true for Ultimate users, as the "Customize system tray icon" function certainly still won't work.
  2. The Win+B combination keys might conflict with some software or environments you use - although I have tested it in some of my common scenarios without any problems.
Please feel free to try it out, and if you have any questions or comments about this workaround, please share them here.
Cheers,
Qiuzy
 Post subject: Re: Fixing SysTray Problem on Win11 by AutoIt Programming
PostPosted: Thu Apr 13, 2023 8:09 pm
Qiuzy wrote:
Hi,
Code:
OpenSysTray()
Func OpenSysTray()
    Send("#b")
    Send("{ENTER}")
EndFunc
Cheers,
Qiuzy
That is an excellent suggestion for an interim workaround, and not only for Nexus users. For users of the Nextstart Taskbar, follow the above instructions but just put a link into the Quickstart area of the Taskbar and you're away.
PostPosted: Tue Apr 18, 2023 2:17 pm
'Bump Topic' not available, so this is just a booster.
PostPosted: Sat May 13, 2023 11:46 pm
This is absolutely fantastic. Thank you so much for sharing this. Works great.
PostPosted: Sun May 14, 2023 1:39 am
Good to know somebody's happy for a change. :)
PostPosted: Mon May 15, 2023 3:27 am
The pleasure is mine. :wink:
PostPosted: Sat Jun 17, 2023 11:03 pm
I knew something like this was going to be a problem when I finally switched to 11. The fact they removed so many functions of the taskbar like just being able to move it to another monitor. I use my sys tray quite a bit and not being able to see it just sucks ;) Thankfully NextStart still gives me to option to have a taskbar elsewhere without it being on every monitor and when I'm gaming I don't need to alt-tab to use the taskbar. Very nice work around here for getting to the sys tray nice and easy...perhaps you would like a job at M$? Could show them a thing or two LOL! Cheers ! :mrgreen:
PostPosted: Sun Jul 30, 2023 5:05 pm
Ok, so I got this working when you click on the Winstep systray expand button (the systray icons even popup next to the button now as before) which eliminates the need for a 3rd party scripting app.
However helpful this is, it does not solve the problem of the missing systray system icons (power, volume, net, etc) or display the icons the Systray tab in shelves, etc...
PostPosted: Tue Aug 15, 2023 1:49 pm
I can't find the Winstep systray expand button. If I add the system tray to the bottom icons I click the icon and nothing happens.
PostPosted: Tue Aug 15, 2023 4:39 pm
1. Are you running the latest *BETA* (v23.7)?
2. Is the 'Always show all system tray icons' setting CLEARED?
PostPosted: Tue Oct 31, 2023 3:34 am
How do I get the beta? I didn't know ethere was one to test.
PostPosted: Tue Oct 31, 2023 3:29 pm
Open NextStart preferences, Select Advanced Tab, check the box "Notify me of beta (test) versions" and then click "check for updates"
PostPosted: Tue Oct 31, 2023 8:53 pm
Eh eh, the guy can't be arsed to answer Jorge's supplementaries for two and a half months and then comes back with nothing but a query where to get the beta?! Bloomin' cheek. Didn't deserve any reply IMO. :twisted:
PostPosted: Fri Nov 03, 2023 8:58 pm
I never received an email notification that my questions was answered.
PostPosted: Fri Nov 03, 2023 9:00 pm
Thank you for the information. It didn't put the dock where I wanted it at first but I've fixed that issue.
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 100 guests
