 Post subject: Flickering Windows Taskbar
PostPosted: Fri Apr 14, 2023 6:18 am
Hi all,
I'm having the issue of flickering windows taskbar when attempting to hide it using nexus's built-in tool, 'Hide/Show Taskbar'. After a while of flickering, the windows taskbar eventually gets hidden, however the nexus dock would have a gap when docking at the bottom, as if the windows taskbar is still present.
Here are my options in the "Position" tab:
To note, I'm trying to replace the windows taskbar with the nexus dock.
Please find a video here.
I'm aware of the recent system tray issue with Win11. Apart from that, is anyone else facing the same issue above or is there a solution for this yet?
 Post subject: Re: Flickering Windows Taskbar
PostPosted: Fri Apr 14, 2023 4:33 pm
This has not been reported by anyone else so far AFAIK.
PostPosted: Sat Apr 15, 2023 10:57 am
I experienced this flickering issue before, it happened when I wanted to use the NeXuS function you mentioned while the taskbar was not automatically hidden.
I'm not sure if this is a bug or not, but you can have a try:
Go to PC Setting → Personalization → Taskbar → Taskbar behaviors → [Check] Automatically hide the taskbar.
Then use NeXuS to hide the taskbar for good.
Users browsing this forum: Amazon [Bot], Bing [Bot], Picco14 and 55 guests
