 Post subject: help Nexus Ultimate.
PostPosted: Fri Jan 27, 2023 12:09 pm
hi happy new year iam korean
Using a translator
winstep nexus->
I'm going to buy Winstep Nexus Ultimate.
But I'm using it with Windows 11.
The work bar disappears.
Is there a solution?
 Post subject: Re: help Nexus Ultimate.
PostPosted: Fri Jan 27, 2023 1:54 pm
Can you please post a screenshot of what you call the "work bar" ? Do you mean the Windows taskbar?
 Post subject: help windows taskbar
PostPosted: Fri Feb 03, 2023 4:55 am
Using a translator
winstep nexus->
 Post subject: Re: help windows taskbar
PostPosted: Fri Feb 03, 2023 3:21 pm
Using a translator
winstep nexus->
You already posted this identical query a few days ago under the title 'Help - Nexus Ultimate', and you had a reply from user/administrator "Winstep" (Jorge Coelho), asking you to clarify what exactly you mean by the term 'work bar' ideally by posting a relevant screenshot. Instead of posting separately again here you should have replied to his answer. (I shall merge your posts.)
While your screenshot is not very clear, I hazard a guess that you mean the Windows taskbar, based on the new title of your second post? If so, check that in your Nexus Preferences 'Hide Windows Taskbar' is not enabled. I suspect it may be enabled. Alternatively, it is likely to be a Windows 11 issue.
Users browsing this forum: Google [Bot], GPT [Bot], Kriller and 67 guests
