 Post subject: how to remove icon?
PostPosted: Fri Jan 20, 2023 6:30 pm
Hey,
how to remove preference and minimize buttons in this tab?
 Post subject: Re: how to remove icon?
PostPosted: Sat Jan 21, 2023 1:30 am
You can't. They're non-optional.
PostPosted: Sat Jan 21, 2023 10:59 am
these ugly icons spoil the effect, especially when I have several this tabs on my monitor
PostPosted: Sun Jan 22, 2023 9:50 pm
Beauty is in the eye of the beholder.....
You could always use a different theme with different icons. Other than that, tough cheese.
PostPosted: Mon Jan 23, 2023 1:10 pm
Yes, but all the skins i tested had THOSE icons.
It would be easier to just give the option to turn it off.
I have 4 of these tabs on my desktop. It looks funny how I have the same icons on each of them.
Unless... I can edit the theme somehow...
PostPosted: Mon Jan 23, 2023 3:31 pm
No, you cannot 'edit' them out. As I said, these tabs and their icons are non-optional and essential to the Workshelf.
There are themes using other icons. Other than that, you'll just have to live with them - as said, tough cheese.
PostPosted: Fri Jan 27, 2023 9:04 am
As Nexter said, those icons are essential to the functioning of the Shelf - it's like asking to remove the close and minimize buttons of a window.
This said, you can replace the icons used for those symbols in that particular theme with a blank bitmap - you would then have to reload the theme for the changes to take effect.
Users browsing this forum: Apple [Bot], Kriller and 60 guests
