 Post subject: NextSTART: Can I add modules to the taskbar?
PostPosted: Mon Nov 21, 2022 11:24 pm
I'm using the trial version of Xtreme and loving the menu editor. But...
Right-clicking on the Taskbar does not seem to offer the option of adding a module.
I've also tried enabling the Clock and Weather modules in Prefrences > Workshelf Section Settings. This has had no effect.
TIA ~ Jeff
 Post subject: Re: NextSTART: Can I add modules to the taskbar?
PostPosted: Tue Nov 22, 2022 12:01 am
WorkShelf must be running for you to be able to add WorkShelf modules to the NextSTART taskbar.
The modules you want must also first be enabled in WorkShelf, and visible on the desktop. Only then can they be captured onto the NextSTART taskbar.
PostPosted: Tue Nov 22, 2022 4:04 am
Aha. Got it. Thanks much. :)
Users browsing this forum: Apple [Bot] and 91 guests
