 Post subject: Menu Icons Question
PostPosted: Tue Aug 09, 2022 4:25 am
Hi,
New user here I'm trying to remove if possible, the icons that precede the entries in Nextstart menus. I've had a look in the menu editor, read through the FAQ's provided and did a search here in the forum but don't see a way to have the icons not show?
 Post subject: Re: Menu Icons Question
PostPosted: Tue Aug 09, 2022 1:43 pm
mizovupi wrote:
Hi,
If you'd explored the various settings in Nextstart Preferences, you'd have found a setting to enable (or disable) icons - can't tell you exactly where as can't access due to being on Linux ATM. Just try again.
Yawn.
How will it all end?!
IN FIRE!
PostPosted: Tue Aug 09, 2022 3:00 pm
Actually, other than switching to a theme that features no icons in the menus I don't think you can do that... but it wouldn't be a difficult option to implement in the future, I think.
PostPosted: Tue Aug 09, 2022 4:11 pm
Ah, heck, sorry, you're right Jorge, I just remembered - we don't have it. It's set by the theme! :) (Most of mine don't use the icons, but some do, as I recall.)
Yeah, definitely would be nice to have this as a user option too, to over-ride the themes settings.
IN FIRE!
PostPosted: Fri Sep 02, 2022 6:49 am
You might like to know that I just added a 'Never Show Icons in Menus' setting to the misc.section of the Advanced Menu dialog. When set it prevents NextSTART menus from showing icons even if the theme allows it.
PostPosted: Tue Oct 11, 2022 4:16 am
Oh wow... both of us fooled by a spam bot.
Turns out this guy copied some text from a 2016 post by another user here in the forums. Then he came back on the first of October, edited his message and added links to porn sites. Luckily I revisited this topic and caught him.
PostPosted: Tue Oct 11, 2022 4:24 am
Damn S-o-B! Good to know he's been caught and banished. Pity bots can't be hung, drawn and quartered. ;)
IN FIRE!
PostPosted: Tue Oct 11, 2022 9:11 am
if hacking worked like young Angelina J showed us, you most prob could
Users browsing this forum: Apple [Bot] and 31 guests
