 Post subject: Is it possible change shelves height?
PostPosted: Wed Aug 03, 2022 5:06 pm
Thanks for help
 Post subject: Re: Is it possible change shelves height?
PostPosted: Wed Aug 03, 2022 5:13 pm
The height, proportions, etc, of a Shelf is theme related.
So, you can either use a different theme OR you can try increasing the scale (right click on the Shelf's left mini-tab -> Appearance and Sounds -> Scale).
PostPosted: Wed Aug 03, 2022 5:30 pm
you can also double click a tab that has more icons than show in a row to show them all, but don't know how long that persists
PostPosted: Wed Aug 03, 2022 7:14 pm
The number of rows (or columns, in the case of a vertical shelf) can also be specified in the shelf's 'Shelf Properties', if memory serves.
However, essentially, the height (or width if vertical) of a shelf, as Jorge already said, is largely determined by the theme. Now, while an experienced 'themer' would have little difficulty changing/adjusting shelf dimensions, it's not something I would recommend ordinary users to even try. :)
How will it all end?!
IN FIRE!
PostPosted: Wed Aug 03, 2022 7:19 pm
To manually increase the number of visible rows you can also left click on a tab (while the Shelf is open/expanded!) and drag it up.
Users browsing this forum: Google [Bot] and 26 guests
