Board index : Winstep Forums : General Discussion  [ 26 posts ] Go to page 1, 2  Next
 Post subject: Weather incorrect again
PostPosted: Tue Jun 21, 2022 12:48 am
The weather is not working correctly again. It shows it to be 15 degrees cooler than it is. I tried the same location name that uses METAR code instead of Weather.com code and it was off by 6 degrees. Another one of the locations near me doesn't work at all, dock icon says N/A.
The 3 day hi/low forecast when hovering over the dock icon seems to be correct.
 Post subject: Re: Weather incorrect again
PostPosted: Tue Jun 21, 2022 1:22 am
Are you already running the beta of v22.4? If not, that is the first thing you should do.
Also, last time I gave you some instructions on how to create a log file. Mind doing that and posting it here?
PostPosted: Tue Jun 21, 2022 1:27 am
Yes I'm running the beta.
Here's the weather.log:
* METAR Connection Failed...
No Valid Codes
No Valid Codes
/wxdata/weather/local/USCA0984?cc&dayf=5&link=xoap&prod=xoap&unit=s&par=1023928134&key=712ce1c26b0de059
wxdata.weather.com
HTTP/1.0 200 OK
Content-Type: text/html
Content-Length: 43
Date: Wed, 06 Apr 2022 20:18:51 GMT
Connection: close
/data.aspx?src=vista&weadegreetype=f&culture=en-US&wealocations=wc:USCA0984
weather.service.msn.com
HTTP/1.0 200 OK
Server: Microsoft-IIS/10.0
X-ActivityId: f7d6317d-6b96-4b9a-88ac-242544b49813
X-AspNet-Version: 4.0.30319
X-Powered-By: ASP.NET
Cache-Control: public, max-age=368
Content-Length: 1497
Connection: close
<weatherdata xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><weather weatherlocationcode="wc:USCA0984" weatherlocationname="Montgomery Field, California" url="http://a.msn.com/54/en-US/ct32.816,-117.141?ctsrc=vista" imagerelativeurl="http://blob.weather.microsoft.com/static/weather4/en-us/" degreetype="F" provider="Foreca" attribution="http://www.foreca.com/" attribution2="Foreca" lat="32.816" long="-117.141" timezone="-7" alert="" entityid="10034044" encodedlocationname="Montgomery+Field"><current temperature="78" skycode="32" skytext="Sunny" date="2022-04-06" observationtime="12:30:00" observationpoint="Montgomery Field" feelslike="78" humidity="62" winddisplay="7 mph Southwest" day="Wednesday" shortday="Wed" windspeed="7 mph" /><forecast low="53" high="71" skycodeday="31" skytextday="Clear" date="2022-04-05" day="Tuesday" shortday="Tue" precip="" /><forecast low="60" high="78" skycodeday="34" skytextday="Mostly Sunny" date="2022-04-06" day="Wednesday" shortday="Wed" precip="0" /><forecast low="62" high="92" skycodeday="32" skytextday="Sunny" date="2022-04-07" day="Thursday" shortday="Thu" precip="0" /><forecast low="59" high="93" skycodeday="32" skytextday="Sunny" date="2022-04-08" day="Friday" shortday="Fri" precip="0" /><forecast low="57" high="76" skycodeday="32" skytextday="Sunny" date="2022-04-09" day="Saturday" shortday="Sat" precip="0" /><toolbar timewindow="60" minversion="1.0.1965.0" /></weather></weatherdata>
Got MSN Data!
PostPosted: Tue Jun 21, 2022 1:40 am
That says temps at Montgomery Field, California, are 78F, and that info was retrieved on 2022-04-06 at 12:30 (local time, I assume).
If that temp is wrong then it is the responsibility of the MSN/Foreca feed.
PostPosted: Tue Jun 21, 2022 1:50 am
The 3 day forecast is the one using the MSN feed. That seems to be correct. The dock icon weather is the one that's incorrect.
PostPosted: Tue Jun 21, 2022 3:31 am
Both the forecast AND the current weather conditions are using the MSN feed. MSN in turn is getting this information from Foreca.
By "dock icon weather" I assume you mean current weather conditions, which, again, are retrieved from the same block of data as the forecast.
If you mean only the icon, it should display skycode="32", which means the clear Sun or Moon icon (depending on the time there) and this also matches the 'Sunny' text in the skytext field of the MSN data block.
If you mean the temperature seems to be wrong, as I said that block of data claims that at 12:30 the temperature was 78F.
PostPosted: Tue Jun 21, 2022 4:49 am
All I can say is the current temperature was wrong. It was showing 61F when it was supposedly 15 degrees hotter. Even now it looks off. It shows 60F when weather.com says it's 67F, wunderground says 68F, NOAA says 66F. MSN says 73F but on its map it shows my location and says 69F. So something's not right.
PostPosted: Wed Jun 22, 2022 2:17 am
Weather's been stuck at 61F all day again. Nobody else has had any problems with the weather icon?
I created a new weather.log. Maybe there's some new info:
/metar/data?ids=KSEE&format=raw
www.aviationweather.gov
HTTP/1.0 200 OK
Server: Apache
Strict-Transport-Security: max-age=63072000; includeSubdomains; preload
X-Frame-Options: SAMEORIGIN
Strict-Transport-Security: max-age=31536000; includeSubdomains; preload
Expires: Wed, 22 Jun 2022 02:21:11 GMT
Cache-Control: max-age=0, no-cache, no-store
Pragma: no-cache
Date: Wed, 22 Jun 2022 02:21:11 GMT
Content-Length: 19881
Connection: close
Set-Cookie: PHPSESSID=cs3eeoec4lb7no7rcbh5ml34q3; path=/
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<!--[if lt IE 9]>
<meta http-equiv="X-UA-Compatible" content="IE=8" />
<![endif]-->
<title>AWC - METeorological Aerodrome Reports (METARs)</title>
<meta http-equiv="content-type" content="text/html; charset=utf-8" >
<meta http-equiv="Refresh" content="900" >
<meta name="DC.language" content="en-us" scheme="DCTERMS.RFC1766" >
<meta name="description" content="Aviation Weather Center Homepage provides comprehensive user-friendly aviation weather Text products and graphics." >
<meta name="keywords" content="aviation, weather, icing, turbulence, convection, pirep, metar, taf, airmet, sigmet, satellite, radar, surface, wind, temperature, aloft, airplane, NEXRAD, GOES, WSR-88D, precipitation, rain, snow, sleet, thunderstorm, en-route, prognosis, chart" >
<meta name="DC.title" content="AWC - Aviation Weather Center" >
<meta name="DC.description" content="Aviation Weather Center Home Page ... METARs Page" >
<meta name="DC.creator" content="NOAA's National Weather Service - Aviation Weather Center Homepage" >
<meta name="DC.date.created" content="2013-03-15" scheme="ISO8601" >
<meta name="DC.date.reviewed" content="2013-03-15" scheme="ISO8601" >
<link href="//code.jquery.com/ui/1.12.1/themes/smoothness/jquery-ui.css" media="screen" rel="stylesheet" type="text/css" >
<link href="/images/favicon.ico" rel="shortcut icon" >
<link href="/images/noaa_logo.png" rel="apple-touch-icon" >
<link href="/css/layout.css" media="" rel="stylesheet" type="text/css" >
<script type="text/javascript" src="//code.jquery.com/jquery-3.5.1.js"></script>
<script type="text/javascript" src="//code.jquery.com/ui/1.12.1/jquery-ui.js"></script>
<script type="text/javascript" src="/javascript/search_auto_comp.js"></script>
<script type="text/javascript" src="/javascript/trax.js"></script>
<script type="text/javascript" async="true" id="_fed_an_ua_tag" src="https://dap.digitalgov.gov/Universal-Federated-Analytics-Min.js?agency=DOC&subagency=AWC&pua=ua-33523145-2"></script>
</head>
<body >
<script>
$(function(){
$(document).on('click', '#maximize', function(){
$('#user_name').css('top','41px');
if('800px' !== $('#map').css('width')) {
$('#user_name').css('top','4px');
</script>
<div id="awc_pagewrapper">
Top header, banner text
<div id="awc_head" >
<div id="awc_header" >
<div class="awc_headerarea">
<div class="awc_headerleft">
<a href="https://www.noaa.gov" title="Visit the NOAA website"><img src="/images/layout/noaa_logo.png" border="0" alt="NOAA Logo" /></a>
<a href="https://www.weather.gov" title="Visit the NWS website"><img src="/images/layout/nws_logo.png" border="0" alt="NWS Logo" /></a>
</div> <!-- /awc_headerleft -->
<div class="awc_headertext">
<h1><a href="/">AVIATION WEATHER CENTER</a><span style="font-size:14px;color:#555"></span></h1>
<h2><a href="https://www.noaa.gov">N O A A</a> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
<a href="https://www.weather.gov">N A T I O N A L &nbsp;&nbsp;W E A T H E R &nbsp;&nbsp;S E R V I C E</a>
</h2>
</div> <!-- awc_headertext -->
<a href="https://www.commerce.gov">
<div class="awc_headerright" title="Visit Department of Commerce website" >
</div> <!-- /awc_headerright -->
</a>
</div> <!-- /awc_headerarea -->
</div> <!-- /awc_header -->
<!-- Header shadow -->
<div id="awc_header_shadow" >
<div id="awc_header_shadow_content" > </div>
</div>
AWC Top Navigation Menu
<div id="awc_topnav" >
<!-- Forecastsearch -->
<div id="awc_menu">
<ul>
<li style="float: left; top: -5px; padding-left: 0">
<div class="" id="fcst-search" style="float:left; width: 165px; margin: 1px 0 1px 0">
<form name="getForecast" id="getForecast" class="form-inline" role="form" action="//forecast.weather.gov/zipcity.php" method="get">
<div id="getfcst-body">
<input name="inputstring" type="text" placeholder = "Local Forecast" class="input_text" id="inputstring" title="Enter City and State, or Zip Code, then click Go" style="width: 110px; !important" />
<input name="btnSearch" id="btnSearch" class="input_button" type="submit" value="Go" style="font-size: 12px"/>
</div>
</form>
</div>
<!-- /Forecastsearch -->
</li>
<li class="awc_link" onClick="" aria-haspopup="true"><span>HOME</span>
<ul aria-haspopup="false">
<li class="awc_link"><a href="/">AWC Home</a></li>
<li class="awc_link" aria-haspopup="true" onClick=""><span>NCEP &gt;</span>
<li class="awc_link"><a href="https://www.ncep.noaa.gov/">NCEP Home</a></li>
<li class="awc_link"><a href="/">Aviation (AWC)</a></li>
<li class="awc_link"><a href="https://www.cpc.ncep.noaa.gov">Climate (CPC)</a></li>
<li class="awc_link"><a href="https://www.nhc.noaa.gov">Hurricane (NHC)</a></li>
<li class="awc_link"><a href="https://www.emc.ncep.noaa.gov">Modeling (EMC)</a></li>
<li class="awc_link"><a href="https://ocean.weather.gov">Ocean (OPC)</a></li>
<li class="awc_link"><a href="https://www.nco.ncep.noaa.gov">Operations (NCO)</a></li>
<li class="awc_link"><a href="https://www.swpc.noaa.gov">Space (SWPC)</a></li>
<li class="awc_link"><a href="https://www.spc.noaa.gov">Storm (SPC)</a></li>
<li class="awc_link"><a href="https://www.wpc.ncep.noaa.gov">Weather (WPC)</a></li>
</ul>
</li>
<li class="awc_link"><a href="https://www.weather.gov/">NWS Home</a></li>
<li class="awc_link"><a href="https://www.noaa.gov/">NOAA Home</a></li>
</ul>
</li>
<li class="awc_link" onClick="" aria-haspopup="true"><span>ADVISORIES</span>
<li class="awc_link"><a href="/sigmet">SIGMET</a></li>
<li class="awc_link"><a href="/gairmet">G-AIRMET</a></li>
<li class="awc_link"><a href="/cwamis">Center Weather</a></li>
</ul>
</li>
<li class="awc_link" onClick="" aria-haspopup="true"><span>FORECASTS</span>
<li class="awc_link"><a href="/convection">Convection</a></li>
<li class="awc_link"><a href="/turbulence">Turbulence</a></li>
<li class="awc_link"><a href="/icing">Icing</a></li>
<li class="awc_link"><a href="/windtemp">Winds/Temps</a></li>
<li class="awc_link"><a href="/progchart">Prog Charts</a></li>
<li class="awc_link"><a href="/taf">TAFs</a></li>
<li class="awc_link"><a href="/gfa/plot">Aviation Forecasts</a></li>
<li class="awc_link"><a href="/wafs">WAFS Forecasts</a></li>
<li class="awc_link"><a href="/areafcst">Area Forecasts</a></li>
<li class="awc_link"><a href="/fcstdisc">Avn. Forecast Disc.</a></li>
</ul>
</li>
<li class="awc_link" onClick="" aria-haspopup="true" ><span>OBSERVATIONS</span>
<li class="awc_link"><a href="/airep">Aircraft Reps</a> </li>
<li class="awc_link"><a href="/metar">METARs</a> </li>
<li class="awc_link"><a href="/radar">Radar</a></li>
<li class="awc_link"><a href="/satellite">Satellite</a></li>
</ul>
</li>
<li class="awc_link" onClick="" aria-haspopup="true"><span>TOOLS</span>
<li class="awc_link"><a href="/flightpath">Flight Path Tool</a></li>
<li class="awc_link"><a href="/gfa">GFA Tool</a></li>
<li class="awc_link"><a href="/hemst">HEMS Tool</a></li>
<li class="awc_link"><a href="/dataserver">Text Data Server</a></li>
<li class="awc_link"><a href="/flightfolder">Flight Folder</a></li>
<li class="awc_link"><a href="/decisionsupport">Decision Support</a></li>
<li class="awc_link"><a href="/pirep/submit">PIREP Submit</a></li>
<li class="awc_link"><a href="/briefing">Standard Briefing</a></li>
<li class="awc_link"><a href="https://testbed.aviationweather.gov">Aviation Testbed</a></li>
<li class="awc_link"><a href="/info/links">Aviation Links</a></li>
</ul>
</li>
<li class="awc_link" onClick="" aria-haspopup="true" ><span style="color: red">NEWS</span>
<li class="awc_link"><a href="/news">AWC News</a></li>
<li class="awc_link"><a href="https://www.facebook.com/US.NOAA.AviationWeatherCenter">Facebook</a></li>
<li class="awc_link"><a href="https://www.twitter.com/NWSAWC">Twitter</a></li>
<li class="awc_link"><a href="https://www.weather.gov/news/">NWS News</a></li>
<li class="awc_link"><a href="/news/front">The Front</a></li>
</ul>
</li>
<li class="awc_link" onClick="" aria-haspopup="true"><span>SEARCH</span>
<form method="get" action="https://search.usa.gov/search">
<input type="hidden" name="v:project" value="firstgov" />
<label for="query" style="color: #104070; font-size:14px">Search For</label><br/>
<input type="text" class="input_text" name="query" id="query" size="12" />
<input type="submit" class="input_button" style="font-size:12px" value="Go" />
<br/>
<input type="radio" name="affiliate" checked="checked" value="nws.noaa.gov" id="nws" />
<label for="nws" class="search-scope">NWS</label>
<input type="radio" name="affiliate" value="noaa.gov" id="noaa" />
<label for="noaa" class="search-scope">All NOAA</label>
</form>
</li>
</ul>
</li>
<li class="awc_link" onClick="" aria-haspopup="true"><span>ABOUT</span>
<li class="awc_link"><a href="/info">AWC</a></li>
<li class="awc_link"><a href="/help">Help</a></li>
<li class="awc_link"><a href="/info/faq">FAQ</a></li>
<li class="awc_link"><a href="/contact">Contact Us</a></li>
</ul>
</li>
<li class="awc_link" onClick="" aria-haspopup="true"><span>USER</span>
<li class="awc_link"><a href="/user/login">Login</a></li>
<li class="awc_link"><a href="/user/settings">Settings</a></li>
<li class="awc_link"><a href="/user/register">Register</a></li>
</ul>
</li>
</ul>
<div style="float: right">
<a href="https://www.facebook.com/US.NOAA.AviationWeatherCenter"><img src="/images/fb-art-25.png" alt="Facebook icon" title="Follow us on Facebook" height="20"/></a>
<a href="https://www.twitter.com/NWSAWC"><img src="/images/twitter-art-25.png" alt="Twitter icon" title="Follow us on Twitter" height="20"/></a>
</div>
</div> <!-- awc_menu -->
</div> <!-- /awc_topnav -->
</div> <!-- /awc_head -->
Main content
<div id="awc_main">
<div id="awc_main_content">
<script type="text/javascript">
function goto(format,hours, taf, layout){
var id_elem = document.getElementById("ids");
var url = "/metar/data?ids="+id_elem.value+"&format="+format+"&hours="+hours+"&taf="+taf+"&layout="+layout;
window.location = url;
</script>
<div id="title">METAR Data<div id="title_linkbar">
<div class='title_link'><a href='/metar?date=' title = 'METAR Home'>METAR Home</a></div>
<div class='title_link'><a href='/metar/plot?date=' title = 'METAR Plots'>Plot</a></div>
<div class='title_link on_page'>Data</div>
<div class='title_link'><a href='/metar/board?date=' title = 'METAR Board'>Board</a></div>
<div class='title_link'><a href='/metar/help?page=text&date=' title = 'METAR Information'>Info</a></div>
</div>
</div>
<div id="awc_main_content_wrap">
<div id = "app_menu" style="height: 30px;">
<form name="textForm" method="GET" action="/metar/data">
<div style="float: left" class="app_text">
IDs:<input size=14 id="ids" class="input_text" name="ids" type="search" title="Enter one or more 4-letter ICAO station identifier(s) separated by a comma. Hit enter to submit." value="KSEE">
Format: <input type="radio" name="format" id="formraw" value="raw" onClick="goto('raw',0, 'off', 'on' )">Raw
<input type="radio" name="format" id="formdec" value="decoded" onClick="goto('decoded',0, 'off', 'on')">Decoded
var e = document.getElementById("formraw");
e.checked = true;
</script>
<input type="hidden" name="date" VALUE="">
<select id="hours" class="input_select" name="hours" onChange="goto('raw',this.options[this.selectedIndex].value, 'off', 'on')">
<option value="0" selectED>most recent only</option>
<option value="1">past 1 hours</option>
<option value="2">past 2 hours</option>
<option value="3">past 3 hours</option>
<option value="4">past 4 hours</option>
<option value="5">past 5 hours</option>
<option value="6">past 6 hours</option>
<option value="12">past 12 hours</option>
<option value="18">past 18 hours</option>
<option value="24">past 24 hours</option>
<option value="36">past 36 hours</option>
<option value="48">past 48 hours</option>
<option value="72">past 72 hours</option>
<option value="96">past 96 hours</option>
<option value="120">past 120 hours</option>
</select>
var e = document.getElementById("hours");
for( var i = 0; i < e.options.length; i++ )
if( e.options[i].value == 0 )
e.selectedIndex = i;
</script>
<input type="checkbox" id="taf" name="taf" onChange="goto('raw', 0, this.checked?'on':'off', 'on');" />Include TAF
<input type="button" id="layout" class="input_button" name="layout" value="Print" onClick="goto('raw', 0, 'off', 'off')">
<input type="submit" class="input_button" value="Update"/></div>
</form>
</script>
</div>
<p clear="both">
<strong>Data at: 0221 UTC 22 Jun 2022</strong></p>
<!-- Data starts here -->
<code>KSEE 220147Z 24007KT 10SM SKC 27/12 A2991</code><br/>
<hr width='65%' />
<!-- Data ends here -->
</p>
</div>
<br style="clear:both;">
</div> <!-- /awc_main_content -->
</div> <!-- /awc_main -->
Bottomo Nav content
<div id="awc_botnav">
<div id="awc_botnav_content">
<p style="text-align: center; font-size: 10px; color: #1150a0">
Page loaded:&nbsp;
<a href="https://www.time.gov">02:21 UTC</a>&nbsp;&nbsp;|&nbsp;&nbsp;
07:21 PM Pacific&nbsp;&nbsp;|&nbsp;&nbsp;
08:21 PM Mountain&nbsp;&nbsp;|&nbsp;&nbsp;
09:21 PM Central&nbsp;&nbsp;|&nbsp;&nbsp;
10:21 PM Eastern
</p>
<div style="display: table-row">
<div style="display: table-cell; width: 100px">&nbsp;</div>
<div style="display: table-cell; width: 200px">
<h1>ADVISORIES</h1>
<ul>
<li><a href="/sigmet">SIGMET</a></li>
<li><a href="/gairmet">G-AIRMET</a></li>
<li><a href="/cwamis">Center Weather</a></li>
</ul>
<h1>FORECASTS</h1>
<ul>
<li><a href="/convection">Convection</a></li>
<li><a href="/turbulence">Turbulence</a></li>
</ul>
</div>
<h1>FORECASTS</h1>
<ul>
<li><a href="/icing">Icing</a></li>
<li><a href="/windtemp">Winds/Temps</a></li>
<li><a href="/progchart">Prog Charts</a></li>
<li><a href="/taf">TAFs</a></li>
<li><a href="/gfa/plot">Aviation Forecasts</a></li>
<li><a href="/wafs">WAFS Forecasts</a></li>
<li><a href="/areafcst">Area Forecasts</a></li>
<li><a href="/fcstdisc">Avn Forecast Disc (AFD)</a></li>
</ul>
</div>
<h1>OBSERVATIONS</h1>
<ul>
<li><a href="/airep">Aircraft Reps</a></li>
<li><a href="/metar">METARs</a></li>
<li><a href="/radar">Radar</a></li>
<li><a href="/satellite">Satellite</a></li>
</ul>
</div>
<h1>USER TOOLS</h1>
<ul>
<li><a href="/flightpath">Flightpath Tool</a></li>
<li><a href="/hemst">HEMS Tool</a></li>
<li><a href="/dataserver">Text Data Server</a></li>
<li><a href="/flightfolder">Flight Folder</a></li>
<li><a href="/decisionsupport">Decision Support</a></li>
<li><a href="/pirep/submit">PIREP Submit</a></li>
<li><a href="/briefing">Standard Briefing</a></li>
<li><a href="http://testbed.aviationweather.gov">Aviation Testbed</a></li>
<li><a href="/info/links">Aviation Links</a></li>
</ul>
</div>
<h1>ABOUT US</h1>
<ul>
<li><a href="/info">AWC</a></li>
<li><a href="/help">Help</a></li>
<li><a href="/info/faq/">FAQ</a></li>
<li><a href="/contact">Contact Us</a></li>
</ul>
</div>
</div> <!-- /table -->
</div> <!-- /awc_botnav_content -->
</div> <!-- /awc_botnav -->
Footer
<div id="awc_footer">
<div id="awc_footer_content">
<div style="width:240px; float: left; text-align:left">
<a href="https://www.usa.gov"><img src="/images/layout/usa_gov.png" alt="USA dot gov"/></a>
</div>
<div style="width:260px; float: left; text-align:left">
<a href="https://www.commerce.gov/">US Dept of Commerce</a><br/>
<a href="https://www.noaa.gov/">National Oceanic and Atmospheric Administration</a><br/>
<a href="https://www.weather.gov/">National Weather Service</a><br/>
<a href="https://www.ncep.noaa.gov/"><span class="gray">National Centers for Environmental Prediction</span></a><br />
<a href="/">Aviation Weather Center</a><br/>
7220 NW 101st Terrace<br/>
Kansas City, MO 64153-2371<br/>
</div>
<div style="width:220px; float: left; text-align:left">
<a href="https://www.weather.gov/disclaimer">Disclaimer</a><br/>
<a href="https://www.cio.noaa.gov/services_programs/info_quality.html">Information Quality</a><br/>
<a href="https://www.weather.gov/glossary">Glossary</a><br/>
<a href="/info">About Us</a><br/>
<a href="/contact">Contact AWC</a><br/>
</div>
<a href="https://www.weather.gov/privacy">Privacy Policy</a><br/>
<a href="https://www.noaa.gov/foia-freedom-of-information-act">Freedom of Information Act (FOIA)</a><br/>
<a href="https://www.weather.gov/careers">Career Opportunities</a><br/>
Server: IDP-CPRK:24 <br/>
Version: v22.04<br/>
</div>
</div> <!-- /awc_footer_content -->
</div> <!-- /awc_footer -->
</div> <!-- /awc_pagewrapper -->
<script>
$(function() {
$('#logout').attr('href', '/user/logout?trax=' + logout);
</script>
</body>
</html>
Error Decoding METAR Data
/wxdata/weather/local/USCA0982?cc&dayf=5&link=xoap&prod=xoap&unit=s&par=1023928134&key=712ce1c26b0de059
wxdata.weather.com
HTTP/1.0 200 OK
Content-Length: 43
Connection: close
/data.aspx?src=vista&weadegreetype=f&culture=en-US&wealocations=wc:USCA0982
HTTP/1.0 200 OK
X-ActivityId: d837fb04-6d1f-4f85-800d-07cc34cb9902
Cache-Control: public, max-age=166
Content-Length: 1470
Connection: close
<weatherdata xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><weather weatherlocationcode="wc:USCA0982" weatherlocationname="San Diego, California" url="http://a.msn.com/54/en-US/ct32.712,-117.137?ctsrc=vista" imagerelativeurl="http://blob.weather.microsoft.com/static/weather4/en-us/" degreetype="F" provider="Foreca" attribution="http://www.foreca.com/" attribution2="Foreca" lat="32.712" long="-117.137" timezone="-7" alert="" entityid="29207" encodedlocationname="San+Diego"><current temperature="73" skycode="32" skytext="Sunny" date="2022-06-19" observationtime="15:30:00" observationpoint="San Diego" feelslike="73" humidity="55" winddisplay="13 mph Northwest" day="Sunday" shortday="Sun" windspeed="13 mph" /><forecast low="56" high="68" skycodeday="31" skytextday="Clear" date="2022-06-18" day="Saturday" shortday="Sat" precip="" /><forecast low="59" high="76" skycodeday="32" skytextday="Sunny" date="2022-06-19" day="Sunday" shortday="Sun" precip="0" /><forecast low="61" high="71" skycodeday="32" skytextday="Sunny" date="2022-06-20" day="Monday" shortday="Mon" precip="0" /><forecast low="63" high="71" skycodeday="34" skytextday="Mostly Sunny" date="2022-06-21" day="Tuesday" shortday="Tue" precip="0" /><forecast low="64" high="76" skycodeday="32" skytextday="Sunny" date="2022-06-22" day="Wednesday" shortday="Wed" precip="0" /><toolbar timewindow="60" minversion="1.0.1965.0" /></weather></weatherdata>
Got MSN Data!
PostPosted: Wed Jun 22, 2022 4:12 am
http://www.aviationweather.gov
What is this? You can't just go and change the weather feed source URLs (Weather Module Settings -> Advanced) without knowing what you are doing or you have been instructed to do so, as it says at the top of that dialog. This **obviously** results in
as the URL you provided ('http://www.aviationweather.gov/metar/data?ids=KSEE&format=raw') is NOT the correct METAR source URL (https://tgftp.nws.noaa.gov/data/observa ... /stations/%1.TXT)
Worse when you don't even say you have done this.
Furthermore, posting a weather log without posting a screenshot of the weather icon AFTER retrieving that same weather data is meaningless to me. You claim temperatures have been stuck at 61F all day but I can *assure you* the icon from the log you posted would actually show 73F.
PostPosted: Wed Jun 22, 2022 4:20 am
I didn't go into Advanced settings. I never changed anything. The only thing I changed were the city locations.
One of the city locations showed 73F, which was also wrong. The one I typically use shows 61F.
There must be something wrong with the dock icon and settings.
PostPosted: Wed Jun 22, 2022 5:43 am
Ok, please right click on the Weather module icon and select 'Weather Monitor Settings'. In the Weather Module Settings dialog click on the Advanced button.
Please take a screenshot of that dialog with all the fields visible and post it here.
Once you've done that click the Default button and see if the content of the fields change. This is what should be visible in the METAR Source URL field:
https://tgftp.nws.noaa.gov/data/observations/metar/stations/%1.TXT
If that is not it and it does not change to that when you click on the Default button, then you must be running an older version of the Winstep application or something. Check the version number in the top right corner of the About tab of Preferences again.
PostPosted: Wed Jun 22, 2022 6:11 am
Here's what it was set to:
and after I clicked Default:
my version:
PostPosted: Wed Jun 22, 2022 6:23 am
It seems to work correctly now if I use the locations that have the METAR code in the weather module settings. If I pick the locations that only use the weather.com codes it shows 61F or N/A.
I'll have to look at it tomorrow during the day to see if it's accurate.
PostPosted: Wed Jun 22, 2022 1:50 pm
This thread peaked my interest yesterday. So in the evening, I twisted the missus' arm to install Xtreme on her remaining Win 10 partition (I've pretty much weaned her onto Ubuntu and that W10 is due to be removed as soon as I can get round to it), with the beta as well, and restore my last backups and my themes.
And guess what the Weather mod came up with!? Connection failed - no data. That was for the MSN feed, according to the Weather Monitor Settings. Didn't change anything, as MSN feed was the only thing available here before. Tried several more times at intervals, same results. Something spooky going on there, certainly. Perhaps MSN feed dead?
Temporarily, it would seem. Just had a peek at 'her indoors'' desktop and it seems all's back to MSN's hopelessly inaccurate usual (can't bring myself to say normal as that seems inappropriate in the context of my location!). Weird.
OK, now to get her to uninstall Xtreme again and wipe all traces of it. Means half an hour's instructions later. :(
PostPosted: Wed Jun 22, 2022 3:42 pm
Yeah, guess what, woke up to my weather module showing N/A too. Forcing a connection via the Weather Settings panel resulted in the current conditions for 20/06 being returned (today is the 22nd) and a single day of forecast (23rd).
Looks like there is something wrong with the MSN weather feed as of right now. Let's hope it's temporary, as this is the last available feed for the time being, besides METAR for current conditions only.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 26 posts ] Go to page 1, 2  Next
Users browsing this forum: Amazon [Bot], Apple [Bot], Google [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 66 guests
