 Post subject: WorkShelf delay
PostPosted: Wed Oct 03, 2007 5:11 pm
When I click on a shelf, it takes about 5 secs. to pop up. This is significantly longer than previous versions. I have version 7.4. The activation delay is set to minimum delay. I have 2 GB of RAM. After the initial activation, subsequent activations (within a reasonable period of time) occur faster.
Any thoughts??
John
PostPosted: Wed Oct 03, 2007 5:57 pm
The very first time you open a particular shelf, icons in it must be retrieved from disk, that is why it might take a bit longer. After that icons are cached in memory and opening that same shelf is much, much, faster.
PostPosted: Wed Oct 03, 2007 6:01 pm
O.K. Thanks.
Users browsing this forum: Bing [Bot], Google [Bot] and 29 guests
