 Post subject: Re: Error creating playlist in Media Player module
PostPosted: Sun Feb 20, 2022 4:03 pm
First things first:
Do NOT give the application Admin privileges. You REALLY REALLY do not want to do that to a program launcher, as anything you launch with it will then also run with the admin privileges. The application SPECIFICALLY warns you NOT to do that on startup.
Try dragging & dropping mp3 files to the Audio Files panel instead. Also, click the Rename buttton to give the playlist a meaningful name.
Users browsing this forum: Apple [Bot] and 68 guests
