 Post subject: icon to default calendar
PostPosted: Mon Nov 08, 2021 2:09 am
someone knows how to put the default calendar of windows 11, in our doc, is that also with that calendar you can see our notifications
 Post subject: Re: icon to default calendar
PostPosted: Mon Nov 08, 2021 11:08 pm
I don't know if that can be done by the "rest of us" because the foundation of Winstep was made well before that particular calendar feature was added to Windows.
I'm pretty sure it would take some work by our absent programmer to get that feature added in.
PostPosted: Mon Nov 08, 2021 11:46 pm
hello friend thanks for answering, you can inform him
PostPosted: Tue Nov 09, 2021 1:04 am
*Major* work I think, if indeed possible at all. (As if there isn't enough major work on the roadmap anyway!)
How will it all end?!
IN FIRE!
PostPosted: Tue Nov 16, 2021 4:49 am
Hello friend, if by chance the implementation of the button happens, how can I find out?
PostPosted: Tue Nov 16, 2021 5:00 pm
The Winstep apps check periodically for an update. So, if you're still running at least one of them, you'll know.
The only other reliable way to find out is to visit this forum.
PostPosted: Wed Nov 17, 2021 1:46 am
Well, you might be in luck. I know how to do it in Win 10. The process should be the same for 11. However, I have no idea if it's the same because MS removed and changed a lot of things in 11.
Click on Start, then type calendar in the search box. Right-click on Calendar, then left-click on Explore. It should open and highlight the Calendar icon.
Drag the Calendar icon onto the dock.
PostPosted: Mon Jan 17, 2022 5:55 am
Is there any sign about a button for notifications?
PostPosted: Mon Jan 17, 2022 9:39 am
Not sure if it will work on Windows 11, but you might get what you want through the **clock** (NOT the calendar) module. What happens when you click on this module can be modified, and one of the options is to show the Windows calendar.
Right click on the clock module, select 'Clock Settings' in the right click menu that pops up, and in the Misc.Settings of Clock Settings dialog change the action to "Open Windows Calendar"
PostPosted: Tue Jan 18, 2022 4:46 pm
Thank you very much friend for answering, I did what you told me but it didn't work, only this comes out
PostPosted: Tue Jan 18, 2022 8:25 pm
Well, there you go, yet another "advantage" of living on the edge: it works on Windows 10, apparently doesn't on Windows 11.
You will have to wait for an upcoming release fixing some of the Windows 11 compatibility issues, sorry.
PostPosted: Wed Jan 19, 2022 8:32 am
ok thank
Users browsing this forum: Bing [Bot] and 15 guests
