 Post subject: Dock: Edit Fly-In and Swing Behaviour
PostPosted: Fri Jan 07, 2022 7:52 pm
Hi Community,
is it possible to disable the "Fly-In and Swing Behaviour" of the dock. Look at the Attachment. Is just want to fly it in without the swinging effect.
Tanks
 Post subject: Re: Dock: Edit Fly-In and Swing Behaviour
PostPosted: Sat Jan 08, 2022 1:51 am
p2000 wrote:
Hi Community,
Tanks
Go to the dock's control icon or right-click any icon to get the context menu and select 'Dock Properties'. Go to the 'Behaviour' tab and click on 'Auto-Hide Settings' which should be somewhere at the top right of this tab. A pop-up appears, with various options. Bee sure to select 'Disable final boing effect'. All this from memory as currently don't have Windows anywhere near ready to go online so some things may be named slightly differently. :)
How will it all end?!
IN FIRE!
PostPosted: Sat Jan 08, 2022 9:26 am
Thanks, that was really self-explanatory and intuitive. Unfortunately I couldn't figure it out at the moment. :)
Users browsing this forum: No registered users and 18 guests
