 Post subject: Increase Menu Legibility
PostPosted: Thu Aug 26, 2021 4:07 am
How do I increase menu legibility? I’ve found how to change the size only. I can’t change menu fonts or boldness. They are just thin low-resolution characters. Depending on what is open underneath them, they can be very difficult to read.
Thanks!
File comment: Example
 Post subject: Re: Increase Menu Legibility
PostPosted: Thu Aug 26, 2021 4:26 pm
Thanks!
Go to 'Preferences' -> 'Themes' tab -> bottom left 'Fonts' button. Here you can change the fonts, font sizes, and font colour. This may not apply to the free version of Nexus though, not sure.
How will it all end?!
IN FIRE!
PostPosted: Thu Aug 26, 2021 4:44 pm
compupix, what theme are you using? Also, which product(s) do you have?
PostPosted: Thu Aug 26, 2021 4:47 pm
Nexus 20.10
Windows10Nx
Thanks!
PostPosted: Thu Aug 26, 2021 8:48 pm
NEXTER, I see no "Fonts" button at
PostPosted: Fri Aug 27, 2021 2:27 am
You must be using the free version of Nexus then - as I pointed out, it may not apply to that version.
IN FIRE!
PostPosted: Mon Sep 06, 2021 8:11 pm
Come to think of it, it may only apply to Winstep Xtreme, as the menus basically take their appearance, fonts and all, from the NextSTART component.
IN FIRE!
