 Post subject: Can I get rid of the yellow arrow?
PostPosted: Mon Jul 26, 2021 9:20 pm
So, when you open Dock Properties, you get this giant yellow arrow pointing to the dock. The thing just annoys the crap out of me, no idea why it just does. Is there any way of getting rid of that?
Magpie
 Post subject: Re: Can I get rid of the yellow arrow?
PostPosted: Mon Jul 26, 2021 11:47 pm
Magpie
So? (The "So" is superfluous, nothing more than a 'fill word' and bad English. :) )
Anyway, no, not as far as I'm aware. Its purpose is to point out the dock that is being dealt with, in case there should be more than one dock. Maybe this should be added to the Winstep Wishlist - annoys me too actually, it should only be an option I think.
PostPosted: Tue Jul 27, 2021 1:09 am
Magpie
Not necessarily, 'so' can be used as an indication of the beginning of something, in this case the story of what is wrong. I admit that it is usually used to indicate that what you are about to say is separate from whatever was discussed before. Using in this manner is very common, at least in my part of the country. It is not "bad English." I'm a native English speaker with a BA, an MA and have 3 and a half years towards my PhD.
PostPosted: Tue Jul 27, 2021 2:22 pm
it CAN be turned off (i have it turned off, (although its blie for me when i pres the 'locate dock' button, but i have no idea where the setting for it is
PostPosted: Tue Jul 27, 2021 4:54 pm
Magpie wrote:
Magpie
Yeah, I know the standards of 'good and proper English' have pretty much gone to the dogs. In my book, in this case 'so' was totally superfluous and inappropriate, it's an American street language 'import' that irritates the hell out of me - much more so than that yellow arrow, actually. The superfluous use of 'so' has acquired epidemic proportions, alas, just like 'like'. And I won't bore you with my academic qualifications, safe to say I went to Oxbridge - i.e., both.
PostPosted: Tue Jul 27, 2021 6:07 pm
Ah, thanks seeker. Good news. I'll check it out when I'm back in Windblows. Got to be able to find it. :)
Users browsing this forum: No registered users and 65 guests
