 Post subject: Sys tray not remebering position
PostPosted: Sun Mar 21, 2021 8:37 am
Every time my second monitor turns off/on my sys tray moves from right side of the screen to the left
https://i.imgur.com/P7nAafX.png
 Post subject: Re: Sys tray not remebering position
PostPosted: Fri Mar 26, 2021 4:15 pm
@nexter, do you think i should merge this with my other sys tray topic (minor issue with sys tray)?
PostPosted: Fri Mar 26, 2021 4:31 pm
Hmm, I could do that, but the problem seems to be more related to multi-monitor issues here so we'll leave it where it is I think, seeker. Hopefully Jorge can shed some light on this soon. :)
Users browsing this forum: Majestic-12 [Bot] and 118 guests
