 Post subject: Nexus Docker and KB4577063?
PostPosted: Fri Mar 05, 2021 10:30 am
Hello. Currently running Insiders build 20H2 or version 19042.546. Last night, with the Nexus docker on the desktop, the above KB was installed. Directly afterward, the ability to run "msconfig" from Task Manager was missing. Further, Task Manager itself would always open to the default blank white square and not remember any Processes that I'd unchecked to NOT be displayed.
I de-installed the Nexus docker and Task Manager would then remember my settings and open properly--once the machine was restarted. Installed Nexus again and Task Manager would only open to defaults with no memory--upon machine restart.
The msconfig run-from-Task-Manager issue--I was able to restore its path in the registry; it had completely vanished.https://19216811.cam/ https://1921681001.id/
Could you take a look at this, please? To clarify--I made a snip of how Task Manager opens upon machine restart with the Nexus docker installed. Only happened after that KB was installed.
 Post subject: Re: Nexus Docker and KB4577063?
PostPosted: Fri Mar 05, 2021 5:33 pm
I am fairly sure this is a Windows issue, not a Nexus Dock one, unless Jorge - the developer of Winstep apps - thinks otherwise, of course.
Users browsing this forum: Google [Bot] and 31 guests
