 Post subject: Odd GPU idle load
PostPosted: Mon Dec 14, 2020 7:58 pm
Hi,
I am new to Nexus Dock. After setting everything up I noticed some very odd behavior. Whenever I leave my system to idle (at desktop with everything minimized) the GPU load jumps to 10-12 % and stays there. If I leave a browser open, the GPU load remains at 0 % in idle. I then started to check which process was causing this. When I close NeXuS the GPU load goes back to 0 % in idle. Clearly NeXuS is the culprit, but I cant figure out what is wrong. I am starting to suspect something foul at play.
Anybody has any idea what the cause is and if it can be fixed?
 Post subject: Re: Odd GPU idle load
PostPosted: Tue Dec 29, 2020 7:04 pm
Absolutely no one is commenting on this... Would be nice if someone could confirm/deny this behaviour on their part.
PostPosted: Tue Dec 29, 2020 8:50 pm
I have no ideas regarding this issue. In the many years of using Winstep products, I've never encountered such.
What program are you using to monitor your GPU usage?
Users browsing this forum: Majestic-12 [Bot] and 23 guests
